TPI intake to Dart Iron Eagle heads?
Have you guys ever seen this gap Ive got between the the intake and the heads?Its in one spot on both sides.Is this normal or is there a fix for this?Maybe Im using the wrong gasket?Ive got the swappers guide and Ive read alot but never heard of this issue.Heres a pic of what im talking about.Thanks.
Hey does anyone know if you can use a 1991 intake on pre 87 SBC heads?I know the center bolt holes are at the wrong angle but I already machined those so they will fit.Hasnt anyone seen this problem before?
Does anyone see this question?Am I a retard and no one wants to answer this?I really need help and I was told I could get an answer here pretty quick.Well its been about 4 hours and no one.Is there another board that really knows TPI stuff?Man I just need some tech help thats all.........
Do you have a gasket down on that? It looks familiar, it's harmless. I had a similar one on my engine, but I was using different gaskets for an HSR so there was "gasket" there if you follow. don't worry about it, as long as the ports line up and seal you'll be fine choking that engine off with TPI
Car: Silver 1980 Corvette (L82 w/TPI)
Engine: L82
Transmission: TH350
My thought is to go with an LT4 manifold with the bolt pattern adapted for regular heads. That way, you maximize the potential of the heads and retain the driveablity of EFI.
1992rs/ss
Jan 31, 2025 05:10 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
