Identifying the year and make a TPI unit is from
Old May 13, 2005 | 01:28 PM
87bigblock's Avatar
Does anyone know how I can find out what year and make a TPI unit came out of? I bought a complete system with heads and manifolds minus the chip but I have the computer and need to find out what car it came out of. Any help would be appreciated. THanks Russ
Old May 13, 2005 | 01:34 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
To start with, find out the part number for the ECM (is it 1227730 or 1227165, etc)... If it is '730, then it came from a '90-'92 F-Body. If it is a '727, it came from a '90-'91 Corvette. If it is a '165, then it came from an '86-'89... You also might look at the plenum and see if there is a spot on the passenger side for a MAP sensor.. If there is (and it has an additional associated vacuum port on that side), then it should be a speed density system (which would mean '90-'92)..
Old May 13, 2005 | 01:48 PM
GOY's Avatar
GOY
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
Look for a cold start injector - 85-88 (maybe 89?) - Do you have sensors? MAF present - 85-89.
Old May 13, 2005 | 11:55 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
from left to right top pic
85-88 cold start injected MAF the driver side runner on the bottem side will have a large hole towards the middle.that is for the cold start injector.this injector will have ahard metal fuel line running to the rear of the driver side fuel rail.
89 MAF no cold start injector
90-92 SD will have three threaded holes for vacume lines on the pass. side
left to right bottem pic
85-89
90-92
the intake base is pretty much the same for all years other than the intake to head bolt holes.85 & 86 the bolt holes were more streight up and down and the 87-92 are more of an angle.
Wecome to Thirdgen.org and remember the function is you friend
Attached Thumbnails Identifying the year and make a TPI unit is from-tpi-plenum.jpg
Old May 14, 2005 | 12:54 AM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
Also look in that pic that 92Bandit2 posted. The plenum 'fins' on the top start further back on the SD plenum.
Old May 14, 2005 | 11:09 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
89-92 has the shorter fins.
Old May 14, 2005 | 06:34 PM
Ozzy88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
Check this site: http://www.hotrodlane.cc/Streetstories/choosetpi1.htm
It has all you need to know.
-Ozzy
Old May 14, 2005 | 10:41 PM
91banditt2's Avatar
Engine: 5.7 HSR
-Ozzy
now THAT! is soom great info
also check out www.chevythunder.com
Old May 15, 2005 | 02:29 PM
Abird4u2nv1's Avatar
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
That pic is the best way to tell, 85-88 has cold start provision, 89 has no cold start and no map sensor. 90-92 have a map sensor
Old May 15, 2005 | 08:52 PM
87bigblock's Avatar
Thanks for the advice. I am really looking for the ECU computer identification. I have a feeling I got sold a computer that doesnt go to the tpi system I bought. The service number on it is 1226485. Does anyone know what car that came out of?
Old May 16, 2005 | 10:34 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Vader Vader Vader
I nominate this post for a sticky and this link is worth its weight in gold.
Awesome info all in one spot between the post and the link every repeated question is answered
later
Jeremy
Old May 16, 2005 | 11:10 PM
91banditt2's Avatar
Engine: 5.7 HSR
for what it's worth i second that nomination.
Old May 16, 2005 | 11:37 PM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
that is very useful,
there was stuff shown that I didnt know about.
very nice
Old May 17, 2005 | 08:53 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Here are the ECM schematics if anyone is interested:
http://www.cruzers.com/~ludis/schematics.html
ECM crossreference page:
http://www.cruzers.com/~ludis/p4xref.html
Ghettobird52
Jul 5, 2024 11:18 PM
Vintageracer
Jan 10, 2020 05:33 PM
Linson
Aug 21, 2015 02:12 PM
jharrison5
Aug 19, 2015 05:53 PM
Street Lethal
Aug 12, 2015 11:33 AM
