ford injectors will fit???
Old May 31, 2005 | 11:09 PM
iroczz89's Avatar
Car: 1989 irocz convert
Engine: 383 tpi
Transmission: 4 spd auto
I am about to replace my stock 19 lb chevy injectors with 30 lb ford ones(as the senior members on here suggested i do)
When i was looking to order them from Summit it looks like all the stats...ie o ring O.D's and overall height is different then the chevy injectors.
Will they still fit on my stock tpi intake or is there a special order # when buying the ford injectors??
Thanks in advance..
Old May 31, 2005 | 11:45 PM
Guest
Guest
Posts: n/a
I'm using them.
You might want to check the o-rings themselves vs the stock ones though, seems like the supply of sizes varies widely and they may be too small.
Old Jun 1, 2005 | 08:28 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Svo injectors work great and I have run the 24 and 30#'s and liked them thus far.
My only beef was as madmax posted, might want to hit a parts store and get a new injector 0-ring kit for a GM as the o-rings are bigger and sturdier to the naked eye. U will see what I mean if u get them, the ford o-rings are defintiely smaller in stature.
later
Jeremy
Old Jun 1, 2005 | 09:33 AM
Hylton's Avatar
Car: A Camaro of some sort.
Anyone have a part number for the Ford SVO 30lb injectors?
Old Jun 1, 2005 | 09:39 AM
3.8TransAM's Avatar
Try Summits website or their catalog or a search :-)
Old Jun 1, 2005 | 02:31 PM
Guest
Guest
Posts: n/a
Actually the ones I got were fine, seems there was a period (and maybe more than one) that Ford was putting larger o-rings on them.
Old Jun 1, 2005 | 04:50 PM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Yes they do work, but they are a rated lower than the ones that came in GM vehicles so the fuel wont be exact, you will be running a little rich than normal.
GMs were rated at 22lbs @ 43psi, were as SVO injectors are 24lbs at 37.5psi. If you are into tuning your own chips, change the injector constant to match, you can use the search button and get some more results about this issue.
Old Jun 2, 2005 | 12:55 AM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
i have ford 19lb injectors on my car and they work perfect. try out www.five0motorsports.com. they have good prices and their customer service is great
Old Jun 2, 2005 | 12:43 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
I believe that both chevy and ford use injectors that are rated at a flow of 43.5 psi. So a 24 lb. ford injector is just that, 24 lbs. at 43.5 psi.
I do suspect however that ford uses a lower fuel pressure in their cars, where as our chevys use ~ 43.5 psi.
Old Jun 2, 2005 | 12:59 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Good way to explain it, mnorton!
Old Jun 2, 2005 | 05:47 PM
Guest
Guest
Posts: n/a
I'm still not in agreement with that theory. I had to adjust my injector constant to ~33 on 30# Ford injectors to get the BLM's back in line, and this is the same thing I have seen many other people do with their 30# SVO's. I've also known of quite a few cars running rich on 24's going from 22's, and not being able to adjust it away with fuel pressure.
If you do a search, someone had Rich from cruizin (I think thats right) flow his injectors and supposedly the flowrate was from 43.5psi. I'm still not accepting that though, I know what I had to do with my 30's with no other changes.
Old Jun 2, 2005 | 07:02 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
madmax..I have 30s also and my injector constant is at 32.9 as well. After much trail and error thats what the motor liked the best. so i know were your coming from.
I read that about rich also....There were others as well on a different forum cant remember which.
Who knows.....
Old Jun 3, 2005 | 08:45 AM
Who knows.....
Even with calculations, the injector constant might not be exactly what is in the car. It's usually easier to lean/richen the fuel across the entire band by changing the constant a little, then fine tuning.
Also, you must add in the the fuel pressure to the equation. My adjustable fuel pressure regulator won't go below 50psi, so coupled with 24# SVO injectors, which I personally believe are rated at 39.5 from what I have read, would be about a 27# injector constant. However, my car doesn't like that much fuel, it was running rich across the board, so I trimmed it a little before fine tunning.
Old Jun 10, 2005 | 08:53 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
That was me, and it depends. Rich told me he's seen various ford injectors be dead on at 43.5, and others at the 37psi or whatever. Maybe the small ones are rated at 37, and the larger at the sae standard?
https://www.thirdgen.org/techbb2/sho...hreadid=219294
-- Joe
Old Jun 10, 2005 | 10:46 AM
Guest
Guest
Posts: n/a
Maybe its totally inconsistent, along with their o-ring sizes.
Street Lethal
Apr 30, 2019 12:14 PM
budofbama31313
Aftermarket Product Review
Sep 16, 2015 12:29 PM
Keith5
Aug 27, 2015 04:37 PM
tmellott89
Aug 16, 2015 02:58 PM
