looking for more h.p from my 305tpi
Old Jun 23, 2005 | 11:27 PM
cuda69's Avatar
Car: 91z28vert,3:42posi-rear,gu6
Engine: 305TPI
Transmission: T-5,pro5.0 shifter
this being my first camaro,I can say today that i love the car,I had reservations at first but the car has grown on me,but now i find myself wanting to go faster,and have decided that a pair of hooker headers are going to be one of my first add ons to this car,Iam looking for any suggestions as for as bolt ons for the car,and would appreciate all info,just want to go a little quicker,and dont have a hugh budget but i always say were theres a will theres a wayright,anyway need advice to gain horsepower!!!
Old Jun 24, 2005 | 10:04 AM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
Headers, Cat-back, high flow cat(s), Port your intake, Free mods. Seeing as you have a 5-speed you are already ahead of the game.
Old Jun 24, 2005 | 12:57 PM
WhiteKnight's Avatar
Car: 88 GTA
Transmission: Manual
wont really help your HP, but will make your engine work much more smoothly. If your car still has stock ignition stuff, get some msd wires, coil, box.
Also a holley fuel pressure regulator would help you out as well with the HP abit. It's relatively cheap as well. Bit over $100 I think.
Old Jun 24, 2005 | 01:11 PM
cuda69's Avatar
Engine: 305TPI
free mods,please explain more,also how do different stall speeds affect a cars performance?
Old Jun 24, 2005 | 01:15 PM
cuda69's Avatar
Engine: 305TPI
also wanted to know if i should change out the stosk shifter,i seem to have trouble getting a fast shift like going into 5 gear on the highway,wondered if a new shift would inprove my shifting,perhaps a b&m or hurst i dont know
Old Jun 24, 2005 | 01:17 PM
cuda69's Avatar
Engine: 305TPI
what kind of money do they get to port an intake like you mentioned?
Old Jun 24, 2005 | 01:29 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
More free mods:
coolant bypass of the throttle body.. gut the air box under the air filters, relocate the IAT sensor to the intake air box.
Old Jun 24, 2005 | 01:34 PM
cuda69's Avatar
Engine: 305TPI
Originally posted by KiLLJ0Y
More free mods:
like i said this is my first camaro must of what you said just went over my head,i got the part about gutting my airbox,should both be done or just one side?bare with me i want to do this right
Old Jun 24, 2005 | 02:34 PM
coolant bypass -----> https://www.thirdgen.org/newdesign/t...ntbypass.shtml
to gut the air boxes just cut the bottoms off the thing and rip out that plastic plate below it so you can see the ground through where the air filters are.
And as far as an Adjustable Fuel Pressure Regulator (AFPR) goes, I got the Crane Cams one for about 60 bucks.
I wouldnt pay sombody to port your intake its pretty easy, all you need is dremel tool or better yet an air compressor and a die grinder. Just do a search about this.... there is TONS of info about it.
Old Jun 24, 2005 | 03:02 PM
Steve89GTA's Avatar
With the car running and vac line disconnected, what fuel pressure do you guys run on your tpi's? I have a stick 305TPI.
Old Jun 25, 2005 | 09:06 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I had a cam, headers, full 3" exhaust, MSD 6A, Blaster 3 Coil, 10.5:1 compression.
Ran a 14.1 @ 99mph with a 2.3 60' time and running in Limp Home Mode.
here is a vid of it in idle and then driving down the street,
http://www.transamws6.com/video/ZepherWS6.mpg
Old Jun 25, 2005 | 04:12 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
see sig for mods
86iroczwv
Sep 3, 2015 06:21 PM
jbd1969
Aug 17, 2015 07:06 PM
rdog30
Apr 6, 2001 07:07 PM
rdog30
Mar 9, 2001 04:25 PM
Stell1579
Aftermarket Product Review
Oct 11, 2000 10:47 PM
