going from a carb to TPI
Old Jun 28, 2005 | 03:36 PM
black85iroc's Avatar
Car: 1985 camaro IROC-Z
Engine: Lg-4 305
Transmission: t-5 5 speed
so i recently found out one of my friends has a complete TPI setup for sale (everything but the wiring harness), and with me going off to UTI this fall, and only being able to have one vehicle i was almost needing to sell my camaro. my concerns were cold winter starts with a carb, and fuel efficiency. i figure with FI, i will be able to start the car in the winter easier and get a little better gas milage. my first question is would this switch help me out with those things, and my second question is i have a decently aggressive cam (.454" lift, and 216 duration at .050") would this mess up the ECU at all? is there a way i can tune it or should i put a milder/stock cam back in?
also how hard is it to rip out whats left of my old harness and completely wire up the new one?
thanks, Adam
Old Jun 28, 2005 | 10:54 PM
Engine: Lg-4 305
no help from anyone?
Old Jun 29, 2005 | 12:03 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
The cam appears to be mild enough to use by the specs you gave but the real determining factor is the Lobe Seperation Angle. You really need a LSA in the 112 or higher to make the computer happy. Have you considered using the Perfect Wiring TPI Harness?...Or even their new system with a dedicated ECU? I'm attempting to go back to TPI soon and the factory harness is a rat's nest of wires. The Perfect Wiring set-up installed in a friends truck was a snap to install. I'm jealous.
Old Jun 29, 2005 | 12:32 PM
Engine: Lg-4 305
where can i find more info on this wiring harness? is it made for TPI or is it one of those universal FI harness's?
oh and i forgot to ask about what am i supposed to do for fuel delivery?
Old Jun 29, 2005 | 01:22 PM
wesilva's Avatar
Transmission: 200R4
http://www.painlessperformance.com/w...cat-fiharn.htm
Universal? They can be installed in any vehicle but they are for F-car TPI's.
You'll need to get an external pump specifically for FI.
Old Jun 29, 2005 | 02:05 PM
Engine: Lg-4 305
damn.... that harness costs more then what i would buy the other hardware for.
Old Jun 29, 2005 | 02:23 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
then you need to either go to a junk yard and pull a complete one(ya.. try and find that) or buy one from either E-bay or a member from here..
Old Jun 30, 2005 | 10:26 AM
Engine: Lg-4 305
i found one guy locally that has a 92 vette setup, he's willing to part with the ECU and wiring, but will it work with a late 80's setup off of a 305?
Old Jun 30, 2005 | 10:27 AM
wesilva's Avatar
Transmission: 200R4
And pick up a GM service manual for your specific year of harness. It will really help you!!
Old Jun 30, 2005 | 10:30 AM
wesilva's Avatar
Transmission: 200R4
I'm not sure if 92 Vette's had VATS but I would avoid it if I could. Just another expense.
Old Jun 30, 2005 | 11:22 AM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
92 Corvette's had the LT1 engine.. the last year of the TPI for corvette's was 91..
if thats from a 92 corvette, its not going to work.
Old Jun 30, 2005 | 07:08 PM
Engine: Lg-4 305
sorry it was a 91
I have a complete 91 Vette setup from lower manifold up w/ Harness and computer with hypertech chip if your interested PM me! Tons of TPI parts left over.
lemme find out the exacty year of the other TPI parts and then maybe i can figure out how compatible they would be...
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
and while you are at it.. ditch that Hypertech chip..
Old Jul 1, 2005 | 09:05 AM
unkuthz's Avatar
Car: 2005 colorado,1975 monte carlo, 2002 yukon
Engine: I-5,350 tpi,327
Transmission: auto
wiring harness
if you dont get that ecm and harness can you find out how much the guy wants for it if he still has it. i have a 727 ecm from a 90-92 vette and i need a harness in a bad way and dont want to spend the cheese for a new one if i can find a good used one. it will beat the hell out of putting the 2 maf harnesses i have together for one speed density harness.
gta90
Sep 15, 2015 04:00 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
