questions on this 350 TPI combo
Old Jun 30, 2005 | 10:18 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i need abit of advice on this......what you think it may make on the motor, and how hard this would be to tune
ZZ4 shortblock possibly, think its 9.6 to 1 comp with 64 cc
comp cams XFI efi cam 218/224
trick flow heads 195cc
accel superam base
AS&M siamesed runners.
base on my searching around, i think that should be good for mid 12's, puttin out about 375hp or so, and pull to 5500rpms. which is where i want it to be
maybe i should try for 10 to 1 or abit higher compression...
what about regular AS&M large tube runners?
if i do go siamesed runners, should i siamese the base at all?
Old Jun 30, 2005 | 10:45 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
EXACT SAME combo last year. Best I could muster up was a 13.4 @104 I had the ASM runners, but I did also have the stock converter and stock chip.
It dynoed 276 RWHP and 324 TQ
Old Jun 30, 2005 | 10:56 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
See my signature. Similiar set up but with Trickflow heads and ZZ9 cam which is smaller. I should be in the mid 12's by the end of the year with a little tweaking here and there.
Old Jul 8, 2005 | 02:52 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
is the 218/224 cam too big for a 350-357 motor with fully modded TPI?
i would like to think it would work great with AS&M siamesed runners and my accel base
maybe i should just fork out the 750 for superram uppers
Old Jul 8, 2005 | 04:33 PM
Car: 1989 GTA
Engine: 369 TPI
No. People here in SoCal are running the 218 degree cam with modified TPI. I'm looking into the XFI cam myself. If you get the proper Trickflow heads with the double springs you can run the XFI cam. Allen
Old Jul 8, 2005 | 10:41 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
yeah thats what i figured, it should make good power
Old Jul 9, 2005 | 10:29 AM
mean57's Avatar
Car: 87 gta
mkos1980
that set-up should have easily put you in 12's
im runnin stck block heads and cam with that intake set-up and pullin 13.5's
Old Jul 9, 2005 | 10:58 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Oh i know, but it didnt lol.
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
When I had just the intake stuff done like you, 14.1 was my best.
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
