Slower car with MODS?
Car: 1989 Camaro Iroc-Z
hey, I have a 1989 iroc-z 350 TPI
Laster year I was running
14.6/14.7's consistent
with Stock 2.77 gears
MSD goodies
Aluminum drive shaft
Poly trans mount
SLP runner ported.
Magnaflow 3in cat-back
This year I added
3.70 gears
24lb injectors
adjustable FPR
Cars running 15.0's
WTF I am upset and about to sell this thing.
MSD goodies
Poly trans mount
SLP runner ported.
This year I added
3.70 gears
24lb injectors
adjustable FPR
Cars running 15.0's
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Did you burn a new chip for it? Adding injector and fuel pressure will only make the WOT PE super super rich unless you tell the computer about it. It's already really rich from the factory. Get a chip burned with the proper injector constants.
Going from an A/F of probably high 11.9's (from the factory) to now probably low 11's maybe 10's will slow any engine down.
Bigger injectors are not an "upgrade" if they aren't needed, and if the computer doesn't know about it.
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
3.70 is pretty high gears for TPI. I wouldnt go over 3.42 with TPI. Now if it was a stick thats a differant story.
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
yep you need a custom chip... those 24's are hurting you right now without the tables being changed in the ECM
Car: An Ol Buick
Engine: Vsick
Re: Slower car with MODS?
This year I added
3.70 gears
24lb injectors
adjustable FPR
Cars running 15.0's
This year I added
3.70 gears
24lb injectors
adjustable FPR
Cars running 15.0's
If your going to get serious about running fast, then I'd suggest you start looking at scan tools, and chip burning.
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
gears
Unless you have about 300 rwhp, a tpi doesn't need and will not respond to any rear gear over 3.42. Your gears are way too deep.
Car: 1983 G20 Chevy
Transmission: 4L60
The gear is not what is making you slower though.
It is TOO much fuel from lack of tuning and the fact that you really need more cam for those SLP runners.
If this tells you anything most engines make max SAFE power with the A/F in the 12.6-12.8 range. As others stated factory w/ 22 lb/hr injectors PE is around 11.9:1 to keep the cat from overheating. With the 24 lb/hr injectors will give you 9% more fuel even with the stock FP setting. That puts you around 10.7:1 in PE. I am guessing you adjusted your fuel pressure to more than you had stock.
Lets say you bumped the pressure from 43.5 to 50. You are now up to 25.73 lbs/hr that is 16.95% too rich. That means you are basically at 10:1 a/f ratio which is going to prevent complete combustion and rob you of power. Depending on where your fuel pressure is try reducing your fuel pressure by several psi and see if you get faster. I would try to shoot for around 37 psi of fuel pressure and see how that makes it run.
Lets say you bumped the pressure from 43.5 to 50. You are now up to 25.73 lbs/hr that is 16.95% too rich. That means you are basically at 10:1 a/f ratio which is going to prevent complete combustion and rob you of power. Depending on where your fuel pressure is try reducing your fuel pressure by several psi and see if you get faster. I would try to shoot for around 37 psi of fuel pressure and see how that makes it run. Last edited by Fast355; Jul 2, 2005 at 06:16 PM.
I Roc AZ, remember, when modifying your TPI, that the approach we took in tuning carbs, doesnt always work for our engines. Alot of gear, fuel, and timing, stall, are not going to give improvements, and as you found out, made your cars performance take a step in the wrong direction. You must make your mods to keep the engine in its "sweet spot", where it makes its max. power and torque. EFI engines that have a lower BSFC generally does not need alot of fuel to make power, especially when the eprom is not tuned for the fuel.
Car: Corvette
With those larger injectors, you'll have to use that AFPR you've got to dial it in and go from there.
Good Luck!
Good Luck!
Good Luck!
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Re: gears
I beg to differ..... it responds REALLLLY well . But I agree the 3,42 's are probably a better choice
. I have the 3.73's now . I can idle along at about 40 km/h in second gear ...mash the throttle and the tires break loose a bit. But also I can hit about 100km/h ( 60mph) and I am at barley 2000rpm ( thank *** for overdrive) Also hp rateings don't dictate gear sizes needed .It's more to do with cams , etc Thread Starter
Thanks for the comments. I had woundered about the ECU needing ot be chipped.
It alos seems like my tranny does not respond as well weither with the new gears.
