Pushrods for 219 cam and TF Heads
Old Jul 9, 2005 | 02:03 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I'm using 7.300 now and by going though alllll the old search posts It seems that with a 560 lift I would need longer ones. I am wondering if this is causing my valve chatter at 3K and up under heavy load.
Whats everybody else using?
Old Jul 9, 2005 | 07:42 PM
brutalform's Avatar
You must check for yourself. Does not matter what everyone else is running. If your block was decked, you may need a different pushrod. Different heads, same thing.
The chatter is probably from misadjusted valves.
How did you adjust yours?
Old Jul 9, 2005 | 11:17 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
while the car is running. i've been doing it for years but this car has to be retarded -5* for it to not chatter.
Old Jul 10, 2005 | 04:53 AM
wackytower's Avatar
Car: 1985 Trans Am
Engine: Superramed 406
Axle/Gears: 10 bolt 3:73
Im using 8.0 length but you have a roller motor.
beastin91rs
Oct 9, 2015 07:38 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
86White_T/A305
Aug 17, 2015 12:16 AM
