good set of heads
good set of heads
hi i have a 91 TBI 350 that im converting to TPI and i have heard that the heads on the TBI motors were crap. So does anybody know where i can get a good set of heads for my 350.
Does anybody know how to tell what kind of motor a remanufactured ecm is off of
p.s im planning on using the chevy hot cam kit
Car: 89 IrocZ
Engine: L98-ish
Heads are open to discussion, so we'll let that one slide...
ECM...service number ending in 165 for a MAF setup or 730 for a SD setup (for F-bodys). Should be able to get a ECM and stock chip out of the classified for 50 bucks or less.
Be careful with your cam choice. The hotcam likes to make power a little higher than a 350TPI likes to rev. I'd say it's too much for a stock TPI. Now an aftermarket or ported set-up might be different.
...JM2C
...JM2C
Car: 89 IrocZ
Engine: L98-ish
Originally posted by mikey72
thanks im glad i know weather its a maf or a SD but do you know how to find out weather its a 350 or a 305 because the guy i bought it from doesn't remember
FYI, but ECM for 305 or 350 is the same...just the chip is different
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Check here:
http://www.efitune.com/broadcast_codes/
should be a 5.0 auto.
That means it's meant for 19 pound per hour injectors, and MAF, and has an external knock module (not in the ECU itself).
NinjaNife
Aug 23, 2015 11:49 AM
Navy8125
Aug 22, 2015 07:13 PM
