stupid question about injectors
Old Aug 27, 2005 | 01:20 PM
mopain's Avatar
Car: 1986 trans am
Engine: 305 tpi
Transmission: th700r4
if the tips of my injectors are fouled, would i still get good ohms readings on them. could this also cause my car to idle rough backfire during excelleration, and have a loss of power.
Old Aug 27, 2005 | 01:33 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
yes.
Run some fuel injector cleaner thru your fuel system. You should do this every 3 months.
Old Aug 27, 2005 | 01:44 PM
greggbruce's Avatar
Car: 84 454 monte, 89 formula, 86 camaro
Engine: the bigger the better
Transmission: 700/4L60 in everything
Axle/Gears: wish they were all 4.10's or better
Re: stupid question about injectors
injectors don't foul, spark plugs do. and yes, it will not change the electrical portion of the injector if it is partially or even completely plugged.
they can get dirty, and injector cleaner will help, the best I have found is made by CONKLIN, it's called "4-Power", very good stuff. you have to become a distributor or buy it from a local distributor, let me know if you have problems getting it. check www.conklin.com and go to the automotive chemicals division.
backfire during accel could be ignition related, bad spark plug wires, cap, rotor, plugs, ect.
I have noticed(that it's more noticeable when it's wet out), if you are maintaining a 50 mph or so speed on a slight hill, a miss is normally caused by bad plug wires. some people mistake this for a trans slip.
check the wires cap and rotor first.
I really need more info for a better answer though.
Old Aug 27, 2005 | 03:13 PM
mopain's Avatar
Car: 1986 trans am
Engine: 305 tpi
i'll give you a breakdown on exactly what happened. about 2 weeks ago it rained really bad here and i got water in my intake. my car stalled but it started up again. that's when it started idleing rough. it backfires in the medium rpm range and wont accelerate. there is also a ticking noise coming from the engine that gets faster as the rpms go up.
i have replaced the plugs, wires, dirstributor cap, rotor, coil, ignition control module, removed the valve covers to check the rocker arms, springs and lifters and found no problem. i have run 2 bottles of sea foam through the fuel system, and i'm quite sure there is no water in the system. i have an adjustable fuel pressure regulator but i'm only running it at 42 psi. \
before this happened i replaced the tps. i have not yet replaced the iac. i checked the noise i reffered to earlier with a stethescope and it is the loudest on the right side fuel rail.
i'm really getting frustrated. i'm not sure what to do now
Old Aug 27, 2005 | 07:47 PM
greggbruce's Avatar
can you isolate which cylinder has the miss by disconnecting the injectors and/or plug wires to see which one DOESN'T make a difference?
how does a hard rain get water in the intake?
you mean like 3 feet of water?
Old Aug 27, 2005 | 08:42 PM
mopain's Avatar
Car: 1986 trans am
Engine: 305 tpi
i will try to isolate it tommorrow morning. i've got 8 new injectors now and i will probably replace them tommorrow anyways.
to answer your question about the water. i've got a homemade cold air intake. i cut a hole through the wheel well and hooked up my air filter there. i live in tx. in the months of aug to mid sep it doesnt' rain hardly at all. i didn't think that not putting a by=pass valve in right away would be a big problem. because of the hurricanes in florida we've had some crazy weather here. i had no clue that the street i turned down would be flooded. it's never rained here like that. but the water came up over my tires.
lesson learned: when you install an intake like this always put in a by=pass valve.
i will let you know about what i find out about the injectors tommorrow, but i think i will replace them all anyways.
thanks for the help\
Old Aug 27, 2005 | 10:23 PM
greggbruce's Avatar
I had a grand am once that had a blown head gasket and filled the cylinder with coolant. the customer didn't know that, and started the motor, it fired on another cylinder and tried to start but wouldn't.
long story short, I replaced the head gasket and got it running, but had a ticking noise, found out it bent a connecting rod and the piston was hitting the counterweight on the crank at bottom dead center.
I hope your motor didn't swallow enough water to hurt something.
if the noise quits or changes when removing a plug wire(obviously while it's running), it's usually a problem with that cylinder.
and I've heard about the texas rains, my brother lives in Houston.
sorry about your predicament.
Old Aug 27, 2005 | 10:28 PM
mopain's Avatar
Car: 1986 trans am
Engine: 305 tpi
thanks for the info. i'll let you know what happens.
Old Aug 28, 2005 | 08:55 PM
mopain's Avatar
Car: 1986 trans am
Engine: 305 tpi
well i finished with the injectors today. i had five injectors with cracked tips. i replaced them and now my car runs immensly better. still idles rough though. i think i'm going to replace the iac next.
Old Sep 5, 2005 | 10:30 PM
Zig's Avatar
Zig
Car: 91 Z28 with 64,000 miles
Had a 92 Chrysler that I took water in the intake with. Torential downpour on unfamiliar roads... End story, two bend rods and a few bent pushrods. Got a complete rebuild and the insurance company paid for it! Said it was covered under the flood portion of the auto policy.
Cleotiz
Jan 6, 2018 08:56 PM
ezobens
Aug 19, 2015 10:29 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
