I Know A Secret To Why.........
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
90-92 SD IROC & Z28 or any Camaro mod to SD can fall out of P.E. mode with modified engines. Can anyone guess why before I tell you?
Re: I Know A Secret To Why.........
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
I'll agree with Kevin C.
Its known on the prom board and even the issue is dissected.
later
JEremy
later
JEremy
Well, its not even every 90-92. Only certain bcc are affected as far as I can tell, might be wrong. BUt the two common ones in those years have a lot of little differences, moreso codewise than actual tune.
later
JEremy
later
JEremy
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
So which BCC's are affected?
aujp positively.
I ran anjf for a long time just for that very reason and some other code issues like 800 rpm in gear max idle and a few other issues that have been well covered there.
I havent traced this particular affliction in the anjf code so it may be there as well, although I cannot confirm 100% either way.
More of a pulsewidth duration issue figured in airflow calcs than anything else though
later
Jeremy
later
Jeremy
Any manual BINs that you know of?
Anyone mind actually converting the abbreviations and acronyms to English so I might try to understand - seeing I have a 91 that I may mod at some point beyond the normal bolt-ons.
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
later
JEremy
later
JEremy
Thanks in advance,
James
The answer is the rubber boot that goes from the throttle body to the intake snorkel. When the weather gets hot the rubber softens up and when you are at wide open throttle in a 5 or 6 speed car and shifting on an off the gas, the rubber collapes between shifts cutting off the air to the engine. I saw this when I was reving the engine. Problem solved!
Car: 1983 G20 Chevy
Transmission: 4L60
How can that keep you from going into PE? The rubber is restricting the intake. I haven't looked at the TPI code but in TBI a restriction will not effect PE. But if the rubber is blocking the intake tract, you are technically pulling a vacuum. That makes the first response right.
When it blocks the air the kpa drops in the 70's and shut the fuel off.
Engine: 3.6L
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
By the way if your rubber boot is collapsing, throw it away and get a factory one. There is no way I can picture a factory boot collapsing. They are pretty thick, and hard to squish by hand.
Car: check
Engine: check
Transmission: check
https://www.thirdgen.org/techbb2/sho...hreadid=202458
RBob.
{edit: fixed link}
Originally posted by 92blue
By the way if your rubber boot is collapsing, throw it away and get a factory one. There is no way I can picture a factory boot collapsing. They are pretty thick, and hard to squish by hand. [/B]
Originally posted by RBob
Observe this thread and the date stamp on it:
RBob. [/B]
RBob. [/B]
JamesZ28 had the same problem and could never figure it out. This is something that needs to be check if you have the same problem.
Engine: 3.6L
Thread doesn't work.
KED85
Jan 19, 2002 11:58 AM
