Plug wires frying
Old Sep 3, 2005 | 09:37 PM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
Plug wires frying
Hey what are you guys doing to keep your plug wires organized?
Ive fried like 2 of mine already from them touching the header.
I know i can wrap the headers and put sleeves on the wires..but i want a clean look also. Ive seen those clips on some cars where theres small clips on the same bolts that hold down the valve cover..and then your run your wires through them in a nice straight line..
pics would be appreciated if you have an idea
Old Sep 4, 2005 | 02:53 AM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
i have the edelrbock street legal headers on my bird, and my plugs dont touch anywhere, i just use a couple of plastic ties on the drivers side wires to hold them away from the headers, and next to something thats not hot. as for the passenger side, my plugs on the cylinders 5 and 7 are both covered with an aluminum coated insulation where they touch the headers. all the wires look clean exept for those 2, but they are next to the firewall, so you cant really tell. i cant see any other way of putting the wires through the headers and not letting them touch.
Old Sep 5, 2005 | 10:47 PM
plathegame's Avatar
Car: 1986 trans am ws6, 66 grandprix
Engine: 88 iroc 5.0 tpi
Transmission: 700 r4 built by rocky pirrone
Axle/Gears: 327
i put the taylor wires from summit on my t/a that run under the car pre cut type because i kept frying the ac delco wires.
they worked great w/ the stock exh manifolds.. i just put on a set of headman shorty headers and the wires fit even better w/ the headers on the car
Old Sep 6, 2005 | 11:53 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
I bought 3 sets of the Taylor clamps and ran them so close together that the wires are thier own structure. Has worked well so far. The only part that was difficult was 5 & 7 near the dizzy.
Once I put the headers on I'll probly have to reconfigure the clamps again though.
They are a PITA in that the screws are EXACTLY the length needed to make the connection. I had to strongarm most of them when using my 8.5mm wires to get the screw started with the clump uncompressed just a bit.
Old Sep 6, 2005 | 06:19 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
For center bolt valve covers, "just Made For You" (or something close to that) will solve your problem. Summit Racing carries this item. I have had them for about 5 years, they work great.
Old Sep 6, 2005 | 11:18 PM
bigchief's Avatar
yeah i've seen those. they are mad good
Old Sep 7, 2005 | 01:31 AM
chickenhawk's Avatar
Car: 86 Monte SS
Engine: LS2
Transmission: 4L65E
I second the "made for you" for center bolt heads.
Here is a pic of my motor with them.
I liked the way they looked as well as the way they kept my wires from cooking.
Regards
Old Sep 7, 2005 | 11:43 AM
bigchief's Avatar
what runners are those that you have on that thing??????? do they flow better than the TPIS runners???
Old Sep 7, 2005 | 01:32 PM
Car: 86 Monte SS
Engine: LS2
Transmission: 4L65E
They are from SlP.
http://www.slponline.com/view_produc...04&BIG=20004-1
They have the potential to outflow them but it takes some time and effort to hog them out along with the plenum as the one I have posted here.
This is not mine, as I didnt take pictures of mine when I did this, but this is where I got the idea.
I plan on putting them on my 1919 formie as well
Old Sep 7, 2005 | 09:28 PM
bigchief's Avatar
awsome, well they are def. very sweet looking
eightsixseven
Dec 16, 2024 01:50 PM
Thornburg
Aug 30, 2015 08:05 AM
g.l.mos
Aug 22, 2015 12:02 AM
djmarch
Aug 19, 2015 12:07 PM
