high park idle low drive idle
Old Sep 5, 2005 | 12:26 PM
sting's Avatar
Car: '87 TransAM
Axle/Gears: 10 bolt 3.23
at first my idle in drive was so low, around 200-300 rpm the engine would or would almost stall, i kicked it up to 500-600 with the throttle body screw using the technical article. however, the idle in park or neutral is high, around 1,100-1300, itll sit at 1100 then seem to just step up a notch and go up. what else should i try? i've read by searching to try the TPS but i havent seen anyone with this odd of a problem either. 200,000mi 305tpi '87 automatic
Old Sep 5, 2005 | 03:04 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: high park idle low drive idle
The TPS adjustment must be done after the minimum air rate procedure, if you don't the ECM will hunt for the idle using the IAC, most likely it's maxing out the IAC. When doing the minimum air rate procedure don't forget to disconnect the set timing connector, you don't want the ECM adjusting the timing which affects idle rpm. Stock tachs are not accurate enough for this procedure, but will get you close, a scanner would be better.
Old Sep 5, 2005 | 10:40 PM
sting's Avatar
Car: '87 TransAM
what is the timing connector? the only thing i read to unplug was the power connection to the IAC valve motor?
Old Sep 6, 2005 | 08:45 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
It the connector in between the two wire looms.
Old Sep 6, 2005 | 09:11 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I believe that you only disconnect the ESC wire when you are setting the static timing.
It would probably help if you cleaned up the TB and the IAC. You have alot of miles on the car.
Then do the minimum air setting according to the article, then reset the TPS to 0.60V, then set the static timing (this is where you disconnect that ESC wire).
A complete tuneup would help also if it has not been done for awhile, new plug wires, dizzy cap & rotor, and plugs. And run some fuel injector cleaner thru the fuel system.
Old Sep 6, 2005 | 10:46 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
I've made this mistake many a time. In the Author column to the left it shows his car is a 305 TPI (unless this isn't the car with the problem,) not a TBI which doesn't have a set timing connector.
Old Sep 7, 2005 | 09:15 PM
sting's Avatar
Car: '87 TransAM
oh, i guess i'm going to have to start over, i didn't adjust the TPS. and the article said nothing about disconnecting a timing wire. i will do this in the next day or so and report back if it fixed my problem
Old Sep 8, 2005 | 07:51 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
if u figure it out i have exactly the same problem with a slightly higher stall in neutral. its around 1400 out of gear and 600 in gear. its actually at the mechanic right now cuz i gave up on it.
Old Sep 17, 2005 | 04:16 PM
sting's Avatar
Car: '87 TransAM
allright well it seems to be fixed, disconnecting the timing advance was def. a helper, then i adjusted the idle screw, then the TPS. at idle the tps is about .42 , is that okay? the idle screw is out like 3/8 of an inch, looks like alot, is that okay? she idles at about 1000-1200 park 500-750 drive now.
also, from searching posts, everyone always jumps down everyones throat about reading the technical article on iac and tps, but there's alot of important information that wasn't even put on the article that make people have to make more posts asking questions, such as disconnecting that timing cable, and it's VERY vague on the whole wire jumping thing and what wires to read with a VOM (because there's three). there's also some very good pictures in some threads i've found that should be added to that article, so everyone doesnt have to spend a half hour digging through what search comes up with.
thanks for the help, that 1300 idle was killing me!
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
Fronzizzle
Aug 19, 2015 01:36 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
