Ijector Help
Old Sep 7, 2005 | 08:02 PM
ZEEYAA's Avatar
Car: 1991 Z-28
Engine: 383 / TPIS MINI RAM
Transmission: 700-R4
Axle/Gears: MOSER 9IN 3.89
Ijector Help
Can someone suggest a brand of injestors that they seem to think are the best. and maybe a size, Just a little history of the engine combo. 383 w/AFR 195s, COMP ROLLER HYD 224/230 X 518/524 112LSA. 1:52 magnum rollers, HSR, 10.2 CPR, 1-3/4 SLPs, w/3in cat back. PRO BUILT 700R4 W/2200 STALL, 9in w/3:89. moats bunrer so I can tune, Thanks for your help.
Old Sep 7, 2005 | 08:50 PM
TPIgirl's Avatar
Car: 89 Irocz
Engine: 350TPI $6E
I think most people on here would recommend SVO 30 or 36lb injectors.
You can also buy a set of 28 lb (LS1 style) injectors for $100 so that's a good deal too.
Old Sep 8, 2005 | 08:53 AM
ZEEYAA's Avatar
Car: 1991 Z-28
Thanks TPIgirl, what combo do you have? what kind of HP do you think 28/30lb injectors will support, and do they change the responsiveness of the engine like a larger throttle body?THANKS
Old Sep 8, 2005 | 08:34 PM
TPIgirl's Avatar
Car: 89 Irocz
Engine: 350TPI $6E
Right now I have a 350 TPI auto in an 89 Irocz.
Well I can only positively speak for the 28 lb LS1 injectors being able to support at least 550 RWHP at 60psi fuel pressure. I don't know the limits on the others though there are charts & formulas on the web to calculate those theoretical limits. Some people measure their power differently, and some people also factor in duty cycle to determine the limits on the injector.
I know you have to adjust the calibration on your chip to get the injectors to match your engine properly, but I don't think you can expect any change in response without retuning for the new injectors.
Old Sep 8, 2005 | 10:00 PM
ZEEYAA's Avatar
Car: 1991 Z-28
Thats cool, I will contact some of the mfg, and see what they recomend because I dont just want to guess. Its a brand new 383 combo and thought someone might have a like combination that would tell me what they are running. I have a 350 tpi now too and it runs really well even though it has 198k on it LOL. Just going to get one ready before it let me down. Thanks for you help TPIGIRL, and look forward to speaking with you again...
Old Sep 24, 2005 | 06:44 PM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
ZEEYYA, if you haven't already found yoru answer for calculating fuel injectors, try this page.
http://www.injector.com/injectorsele...891aabc14d0044
Old Sep 25, 2005 | 09:06 PM
ZEEYAA's Avatar
Car: 1991 Z-28
Thanks very much BOSS355..
Old Sep 25, 2005 | 10:10 PM
BOSS 357's Avatar
Engine: 357 SBC TPI
You're welcome ZEE. Just be sure to notice that all the calculations are done at 43.5 psi, as by reading this board enough, you will probably be adjusting the fuel pressure upward of that.
Eric
Bobby Suth
Oct 21, 2012 05:55 PM
ervin
Feb 10, 2012 09:54 AM
89trans am
Sep 6, 2011 08:53 AM
Bobby Suth
Dec 12, 2010 02:16 AM
