hsr, heads, cams
Old Sep 21, 2005 | 02:05 PM
fastcrazyhurt's Avatar
Car: 1990 trans am gta
hsr, heads, cams
i have done some research now for some time and have concluded that a holley stealth ram, heads, and cam is what i need to be at 12's. i need some imput on what heads to buy and cam to go with the stealth ram. i also have a bad MAF sensor and before i buy a new one was wondering if i should wait incase any of these parts need an upgraded MAF. i already have header and exhuast. and also am buying a ram air 2 should i get with or without airbox will it be affected by the HSR
thanks james
Old Sep 21, 2005 | 03:01 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Before you going on talking about stuff your barely know about, IE heads, StealRam ect.. make sure your car is in solid mechaincal order. A tuned stock car is usually faster than a crappy tuned, non stock car.
A88GTANotchback's Avatar
search man. tons of info ou tthere. ive been searching all day and found that a HSR coupled with AFR, or TFS heads, with a hot cam(not the best)will net a 12et you can use a 224-230 for comp or a custom grind. again search and it will fill in the blanks. i used HSR cam combos i think and got tons.
Old Sep 21, 2005 | 03:55 PM
stock
the car is stock and all original 1990 trans am gta with 50,000 miles on it. there is actually headers and exhuast already on it. the only problem is the stock paint is bubbling. if you know so much shed some light on me and help out i have researched for 3 weeks now and am sick of reading so much. i just want a cam part number and i will probably go with afr 195cc heads and the stealth ram. no where on here does it say if the ram air 2 hood wit hairbox get in way of holley stealth ram. thanks james
Old Sep 22, 2005 | 11:02 AM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Re: stock
Hey let's try and keep it clean would ya?
Have a Ram Air hood with HSR but no air box but I would imagine it would be not problem.
Old Sep 22, 2005 | 11:29 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
You WILL need to burn your own proms to get it to run right with that combo so save some $ for that equipment and do it right or the HP rewards will be less than expected.
Old Sep 22, 2005 | 02:37 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
If you want to be fast, get a higher stall converter and a cam matched to that and the heads.
The airbox should be fine, but you will have to mod it slightly to get the MAF to sit between it and the HSR.
Old Sep 23, 2005 | 12:39 PM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
Only 3 weeks and your already tired of reading?
**** im working on 3 years and loving every minute of it... (4got my PW on my 1st account)
hah my girlfriend hates TGO cuz i spend more time here then with her and we live together...
If your going to do all those mods your going to want to address gearing and traction issues as well... Hooking up makes a huge difference in ET's
Mickeyruder
Sep 2, 2015 02:45 PM
michealleger
Aug 26, 2015 03:29 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
86White_T/A305
Aug 17, 2015 12:16 AM
