When do you need to start tuning?
Old Sep 29, 2005 | 07:12 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
I have been searching around for new ways to setup my intake. My motor is the zz1 and i have a stock 305 tpi on it right now. so, the motor needs more air. I have thought about going to carb, or maybe just a ported tpi. i figured out that the only alternative port efi that would work with my 1204 corvette heads is the miniram, and thats a lot of money i dont have. so basically i am deciding between a ported tpi (or whatever you wanna call it with new runners, ported plenum, etc.) and a carb. What seems like the more reasonable thing to do here, and what kind of money am i looking at (used is ok with me). also where should i go to find a ported tpi setup? thanks a lot.
Old Sep 30, 2005 | 01:18 AM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
How about a stealth ram or super ram? The stealth ram will set you back about $500 for the manifold and fuel rails if you buy it all new. Thats half the price of the miniram.
Old Sep 30, 2005 | 01:19 PM
ZZ4 86 Z28's Avatar
i considered that, but the stealth ram requires a 1205 port on your heads and i have a 1204, and i dont feel like porting my heads.
Old Sep 30, 2005 | 01:22 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
The miniram has a smaller port than a stealth ram? That doesn't sound right.
Regardless of what intake and heads you use, they will not match perfectly. Some minor porting will be ideal regardless of what route you take.
Have you taken a look at the ports on a stock TPI intake and compared them with the ports on stock TPI heads? On my 416 castings, there were a couple of places where it was off by 1/4 inch.
Old Sep 30, 2005 | 01:28 PM
ZZ4 86 Z28's Avatar
well the miniram has like 4 different port size options and 1204 is one of them, plus miniram is way too expensive. plus i dont have stock tpi heads. i have aluminum corvette heads, and no i have not checked to see if they match.
Old Sep 30, 2005 | 10:43 PM
ZZ4 86 Z28's Avatar
anyone else have any suggestions?
Old Oct 1, 2005 | 01:54 AM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
You do know that Corvette aluminum heads were stock tpi heads on the Corvettes, right?
Old Oct 1, 2005 | 09:38 AM
ZZ4 86 Z28's Avatar
yes.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
ezobens
Aug 19, 2015 10:29 PM
355tpipickup
Aug 13, 2015 07:35 AM
mizz0313
Aug 12, 2015 06:45 AM
