New MAF Sensor
Old Oct 4, 2005 | 08:10 PM
dgc1's Avatar
New MAF Sensor
I am about to replace the MAF sensor, but before I put in the new one, I am trying to check everything out so I don't burn it out.
I connected a digital volt meter between pins A & E and when I started it, I got 14 Volts. I then connected the volt meter between pins A & D and expected to see 12 V when I turned the key off. I heard some buzzing from one of the relays after the key was off, but no voltage between A & D. Is this correct? Both Maf relays have the same number on them. The number on them is 10038311 9137. Are these the right relays?
Thanks,
Don
Old Oct 4, 2005 | 08:34 PM
Kwiksilverz28's Avatar
The buzzing from the relays is the MAF burnoff function. Check this out... may help
Old Oct 4, 2005 | 09:10 PM
dgc1's Avatar
Good Wiring Diagram
Thanks for the reply!
I used this diagram to determine that there should be voltage between pins A & D on the MAF plug when you turn off the key and the burn off relay pulls in. I did not get any voltage. Am I wrong in what I am expecting?
Don
Old Oct 5, 2005 | 10:21 PM
Tell me what is the issue other than your findings.... Codes? I can give you diag charts for which codes. These are out there. Do a search for your issue and you will not believe the results....
Old Oct 6, 2005 | 08:49 PM
dgc1's Avatar
MAF
Silver,
I hooked up a Snap On reader and it showed The Maf was low when it was running. Unplugge the maf and it read high. I got a new maf, but I am trying to check everything out before I install it. Am I correct that when I shut the engine off, there should be voltage for a few seconds on the burn off line going into the maf sensor. I don't read any voltage, so I am wondering if the burn off relay is bad or the wrong one. The numbers on both of the maf relays are the same. I just got the engine and don't know what the PO has done to it.
Thanks,
Don
Old Oct 6, 2005 | 10:19 PM
MAF and burnoff relays are the same.
Here is the chart for low flow....
Old Oct 7, 2005 | 09:11 PM
dgc1's Avatar
Thanks for the chart! I will check it out according to this. Probably will be Sunday or Monday before I get a chance. I'll let you know what I find,
Don
Old Oct 12, 2005 | 10:29 PM
dgc1's Avatar
Replaced MAF
I installed the new MAF. Now the SES light stays off. It doesn't idle right yet. RPM goes up and down until it warms up. Then it gets a little better. I am going to take a look at the IAC next.
Any other ideas?
Don
BumpaD82
Feb 26, 2016 02:57 PM
sleprock
Oct 1, 2015 09:39 AM
Racerx974
Sep 19, 2015 10:16 AM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
earlpote
Sep 12, 2015 11:55 AM
