Quick SLP Cold Air Intake Question
Old Oct 13, 2005 | 11:35 PM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
As of now I am using K&N air filters. If I got an SLP cold air intake kit would this kit replace the K&N's? Or could I use both thanks.
Old Oct 14, 2005 | 09:56 AM
i8myz28's Avatar
Car: 86 z28
Engine: 355 TPI W/305 HEADS
Axle/Gears: 3/73's
look at the ram air box at hawks or make your own..try a search its here somewhere.....good luck..
Old Oct 14, 2005 | 11:13 AM
Car: ws6
Engine: ls1
Transmission: m6
Here it is...
Old Oct 14, 2005 | 11:34 AM
Car: ws6
Engine: ls1
Transmission: m6
Would this one be a better choice? This is from Hawks...
z28 NyC's Avatar
Car: 1986 Camaro z28
Engine: 305 tpi/light mods
Transmission: 700r4/ B&M mega shifter
I dont think that would make sense because he doesnt have a ram air hood also the slp ram air is for birds, your lucky to have a camaro we have the best air intake setup go for the ram air from hawks.
Old Oct 14, 2005 | 01:02 PM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
The slp setup replaces everything from the tb to the box including a new k&n filter.
Old Oct 14, 2005 | 01:55 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
It won't flow much better than the stock intake setupwit K&Ns, just gut the boxes and that is more than enough airflow. Spend the 250 dollars on something else.
Old Oct 14, 2005 | 05:08 PM
Car: ws6
Engine: ls1
Transmission: m6
HAHA I think you already told me this before maybe I should listen this time...... I think your right K&N's usually work really well. The SLP maybe a waste of 250 dollars. Thanks for the responses I think I am just going to mod the air box.
Old Oct 14, 2005 | 09:24 PM
vortec77's Avatar
Car: 86 T/A
Engine: 2000 TPI 5.7L vortec L31
I know this set up isnt as good as the ram air set up for camaro's, but i think it looks pretty cool for a bird and id rather have that set up than the stock air inlet mostly for the looks. May ask if u got a price on this set up?
Thanks,
Old Oct 15, 2005 | 08:30 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Grab the cold air from inside the fenders or from behind the fog lights, just get cold air! I like my dual SLP cold air and I paid a fraction of the 250 by picking one up used.
There have been some pretty cool boxes that slide down behind the hood latch and into the space behind the fog lights I've seen. Remember, with the SLP dual cold air you have to move the battery, a royal pain in the butt.
I used to have a home made cold air that dropped to the driver side battery box area on my Camaro. The K&N hung under where the vacuum ball was for the cruise control.
Worked pretty well.
Old Oct 15, 2005 | 08:32 PM
z28 NyC's Avatar
It makes absolutly no sense to put the slp ram air in a camaro
1992 Trans Am
May 10, 2023 07:19 PM
kyle5647
Aug 15, 2015 11:56 PM
Jake_92RS
Aug 11, 2015 10:39 AM
