car wontrun or idle
Old Oct 18, 2005 | 01:54 AM
ponykiller1992's Avatar
Car: 89 formula 350
Transmission: Stock 700r4
car wontrun or idle
Ok, I removed my plenum and TB to clean them. I also changed my plugs. I got cought up with work, and the car sat for 6 months with less than 1/4 tank of gas. Well, I finally got time to work on her, so I put the plug wire one and bolted the plenum back on. After hooking up all the vacuum lines, I went to fire her up. She fires, but wont idle without dieing. I have to keep giving her throttle. I am not getting any codes, and I never touched the timing. She ran fine before minus the bad exhaust leak. I tried hooking up a vac gauge but since it wont idle, I cant get a good reading. Any idears?
87 350 TPI
Oh yeah, the motor shakes like crazy when I give it gas or when it attempts to idle. Didnt do this before.
Old Oct 18, 2005 | 09:52 AM
unkuthz's Avatar
Car: 2005 colorado,1975 monte carlo, 2002 yukon
Engine: I-5,350 tpi,327
Transmission: auto
fresh rebuild
mines doing the same thing on a fresh rebuild. i evidently have my egr block off plate on wrong and this is making 3,4,5,6 not fire due to no o2 because of bypass on the egr passages. could be the problem. not too experienced with the tpi but sounds like the same situation im in. might be a bad egr.
Old Oct 18, 2005 | 11:58 AM
Shagwell's Avatar
Car: projects.......
- sounds like a EGR screw up. - Sure you got the vac lines run correctly?(little one to it and the little one under the throttle body)
Old Oct 18, 2005 | 12:02 PM
Shagwell's Avatar
also, check ALL vaccum lines. should be 3 on the plenum(fuel pres. reg/supply for vehicle(a/c...)/brake booster), one little one under throttle body(egr solenoid), then the 2 on the side(coal canister/breather)
Old Oct 18, 2005 | 02:05 PM
Car: 89 formula 350
Checked the vac lines like 3 times to make sure they matched the diagram I had.
Old Oct 18, 2005 | 03:39 PM
Shagwell's Avatar
You sure no gaskets slipped while putting the plenum(etc...) back on? just sounds like it's got a vaccum leak...
Old Dec 28, 2005 | 08:15 AM
89BlueRSCamaro's Avatar
Car: 1989 IROC-Z
Engine: 350-5.7L
Transmission: 700R
hey can you tell me how they go..i think i have a similar problem and i already replaced the MAF and IAC and the car just wont idle...also was running a little to rich for FPR problems and pressure was good so i am replacing the injectors but i have suspected that i have my vacuum lines set wrong...so can you upload the diagram that you checked yours against...thanx and sorry for stealing some thunder from your thread
Old Dec 30, 2005 | 10:07 PM
upandcoming's Avatar
Car: 88gta
Engine: 357
Transmission: 700r4/3000 stall convertor
Axle/Gears: 9 bolt 3.27
sound like you didnt get the gaskets sealed good... had the same problem when I changed the fuel pressure regulater
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
