replacing 305 with 383, identify some parts off old motor
Old Oct 22, 2005 | 06:08 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
three things i need identified right now...there is a black box connected to the pass side of the plenum (pic 1) what is that for?
next is a black piece with a couple vacuum hoses running to and from it (pic 2). its located right next to the coil, what is that?
finally what is the sensor ocated under the plenum used for?
Old Oct 27, 2005 | 02:57 AM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
The black box is your MAP sensor.
The second thing you mentioned is a vacuum check valve for the HVAC/cruise.
The IAT sensor is located under the plenum.
HTH
Old Oct 27, 2005 | 02:16 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
thanks for the help. i was told however the second part was the egr soleniod...its vacuum lines run to the egr under the plenum.
Old Oct 27, 2005 | 04:50 PM
Jade Grey's Avatar
Engine: 305TPI
Your second picture (pic 2) does not appear in your original post. There is only one picture file attached to this thread.
I was making an educated guess from the information you supplied about the unknown part. Yes, the EGR solenoid is also in that area and has lines running to the EGR valve.
Old Oct 27, 2005 | 05:11 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
ok thanks for the help, i now know what the other piece is around that area!
jhawkeye
May 25, 2022 06:33 PM
st.evel07
Aug 13, 2015 06:15 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
Leggman1
Aug 6, 2015 04:15 AM
