What gasket to up compretion for 305 tpi
Old Oct 30, 2005 | 08:24 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
I'm not sure what bore size or thickness to go with. I have 081 casting and was told stock I have 9:3:1.
I will be running a
95 Lt1 cam
95 Lt1 intake
Hooker super comp shorties.
Higher compretion on 87 octane. Please help.
Old Oct 30, 2005 | 09:01 PM
stubbs's Avatar
Car: 1987 Corvette
Engine: 383 TPI
Transmission: 4+3
I know TPIS has 350 gaskets that ups the CR by half a point but I don't know if they have one for a 305?
Old Nov 1, 2005 | 04:01 PM
Car: 2002 SS
Engine: Ls1
bump
Old Nov 1, 2005 | 04:18 PM
Guest
Guest
Posts: n/a
There isnt one. You already have a thin gasket stock, the only thing thinner would be to run no gasket at all.
Have to go another route to up your compression ratio.
Old Nov 1, 2005 | 04:19 PM
Car: 2002 SS
Engine: Ls1
aw k.
Old Nov 4, 2005 | 10:58 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Felpro 1094 the compressed thickness is .015. The only thing with these are, they are a rubber coated shim and everything has to be flat in order for them to seal correctly.
Now with that said, I just slaped them on there and called it good. lol
Old Nov 4, 2005 | 07:25 PM
Car: 2002 SS
Engine: Ls1
is that a stock replacement? Or will that up to cr. I wonder what it will be with that gasket
Old Nov 4, 2005 | 10:26 PM
Guest
Guest
Posts: n/a
Practically nothing.
https://www.thirdgen.org/techbb2/sho...sket+thickness
Old Nov 4, 2005 | 11:02 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
What Max said. about .5 of a point.
Orr89RocZ
Apr 25, 2016 08:28 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
