Best Cam
Car: 79 ELKIE
Engine: TPI 305
Best Cam
Hi all
Can anyone tell what the best cam would be for me to use in my 1985 305 TPI its rated a 210 would like to get it up to 350 or so but what to keep pertty much stock any help its back with a 700R4
Car: 1994 Jeep Wrangler
Originally posted by pitzzilla
Well that only good when racing my car will be seeing street Im sure a cam will benif some
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
yeah 350 out of a 305 will require alot of head work, full TPI port job or better yet, a aftermarket TPI setup or superram/hsr... basically alot of intake work. and a nice cam. then ur gonna need to tune it up.. which the 85 ecm i'm not sure is really a good ecm. might be better to swap to the later 89 ecm without cold start injector. its a better ecm.
something on the lines of a 219/219 lingenfelter on a superram or fully aftermarket TPI and ported heads or aftermarket heads
for mostly stock setup.. on a 85.. which i do believe is a flat tappet cam... try something with the intake/exhaust duration in the 210-216 / 216-220 range. a roller cam setup swap would be a good idea. a zz4 wouldnt be bad at all. but with a cam, ur still gonna have to tune it up.
with full bolt ons and a cam, maybe some head work too, i would say up to 275hp or so on crank
Car: ws6
Engine: ls1
Transmission: m6
I say it would be cheaper to just drop in an LS1 350 crate motor. To get 350 hp out of an 85 305 will NOT be an easy job. FULL bolt ons, Exhaust/Runners/Intake/Filters/Chip/Ignition/Port job/Heads/Cam then a supercharger with a 6-8 boost will get you up there. Then you are going to have to think about a new tranny and suspension parts to handle the extra power.
Car: 79 ELKIE
Engine: TPI 305
A crate engine would be the way to go but I have kids need my cash for them so I have a complete 305 TPI looking to better it befor installing it thanks for the help I gess I'll have to wait till the trun 18
Car: ws6
Engine: ls1
Transmission: m6
How much are you looking to spend? How fast do you want to go? You don't need a 350 horsepower 305 to go fast. With just bolt ons you should be able to get your horsepower up in the ball park of 245-260. Those numbers will make a quick 305.
Car: 89 Iroc-z
Transmission: TH400
350hp needs heads and cam.. i doubt u will need boost on top of that...
i would just boost it period.... spend 3 grand a procharger and u got 350 easy. probly 400 and it should hold for a while under daily driving condtions. constant abuse and ur asking for abit of trouble but 350-400 crank hp on stock internals shouldnt be a problem at all.
