Carb to TPI
Car: volvo
Engine: 1978 305 w/TPI
Transmission: 1982 B/W T-5
Carb to TPI
About 3 years ago, i did a v8 conversion on a 200 series Volvo using a 1978 305. It has a Carter carb on it and I was wondering if it would be practical to convert to a TPI intake setup or buy a complete late 80's camaro engine with the intake, harness, computer and sensors already there. I have been very interested in doing this conversion for quite some time now and a complete setup from a friend is available to me for $300.
I ran a search for "carb to TPI" and it seems that there are several problems with wiring harnesses and tuning when converting, however, i'm still interested in following through with the swap.
Thanks,
V8volvoman
Thanks,
V8volvoman
For 300 bucks and a complete setup that seems to be good, when you say complete do you mean just the intake or do you mean intake setup + injectors + fuel rails?
A TPI setup on a relatively mild 305 will wake it up quite a bit. The thing to remember is where does your current motor build power? If its a high revver a TPI setup may not be want you want. But if its a typical 305 with pretty standard parts then revving to 5000 rpm will be plenty. If thats the case the TPI setup is perfect.
Car: volvo
Its a completely stock 305.
The setup will come with everything from computer, to wiring harness to the injectors.
I heard from some people though that the bolt pattern that the intake sits on is different from mid 70's to when the TPI was introduced. I want to make sure that the TPI intake is going to fit before I buy it. If its compatible then great, if not, then ill have to find a complete engine.
300 bucks for everything is dirt cheap.
As far as I know TPI setups are Gen I blocks and they have the same bolt pattern as all the previous small block chevy's. You'll want someone else to confirm this, I've been out of the loop for a while and am trying to get back up to speed myself. But I think the LT1 is the first block you'd have to worry about bolt patterns on.
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
if it's an 85 or 86 TPI intake than it will bolt up no problems.
87 up have a different angle on the 4 inner bolts. The intake can be machined.. holes elongated to match though.
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Just in case your interested... here is a nice setup I have for sale.
The 87 and up intake are the exact same except for the inner 2 intake bolt angles on both side. A little slotting work and your ready to go on the older gen 1 blocks.
http://cgi.ebay.ca/TPI-intake-with-N...QQcmdZViewItem
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
personally I would try get get an entire car. THey can be had for about $600 from a junkyard.
Thats exactly what I did, I swaped everything over and it looked absolutely factory.
One thing to consider is you should use new fuel lines as the TPI ones were made for higher pressure than the carb ones. And you need to put an in-tank high output Fuel pump...
John
John
Car: volvo
Thanks for all the replys. I am going to look into what the costs are for machining the intake as well as a whole car. But based on what people have said here, I'll go for the $300 setup my buddy has.
Thanks again,
V8volvoman
Thanks again,
V8volvoman
beachrodder
Aug 25, 2015 08:05 AM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
