check out my TPI swap (pics)
Old Nov 12, 2005 | 04:42 PM
SatisTraction's Avatar
well its not your usual camaro TPI swap. This truck was bought new by my grandpa in 1985 and passed on to me just before he passed on I promised to keep it alive. For the last three years it has been parked but now she is kicking again.
I still have to get a lokar TPI kickdown cable and ath350 VSS but she does run now!!!
Thanks for the help on here.
Old Nov 12, 2005 | 04:58 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
L98 350 or LB9 305? How does it run? Looking good.
I went with the other option on mine. TBI swap.
Old Nov 12, 2005 | 06:40 PM
305. i have a 350 on the stand but it will be a while before i do that. runs great.
Old Nov 12, 2005 | 08:24 PM
80Sierra's Avatar
Car: 80 GMC K35
Engine: TPI 355
Transmission: NV4500
Axle/Gears: 4.10
Looks awesome!
I'm still in the process of putting a SM465 (granny 3 speed) into my truck, and working on a speed density conversion, so its gonna a be a little while before mine hits the road
I'm excited though, I haven't driven my baby in like 14 months!
Old Nov 12, 2005 | 08:46 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Yep, it looks like a nice clean installation. I bet your grandfather would be proud of his truck. That combination makes for a good truck motor. Well done.
Old Nov 13, 2005 | 12:10 AM
S10Wildside's Avatar
I'm also working on a similar truck. We should have the engine running on Monday. It's a hodge podge, but for the most part it's a 1983/1986 K10. There's a website decidated to this carb to TPI conversion. http://www.eficonnection.com/eficonn...10/default.asp
Old Nov 13, 2005 | 12:15 AM
What A/C lines did you use?
Old Nov 13, 2005 | 05:55 AM
thats the original 1985 truck lines. they do not fit very well though. that is on the "do it" list.
i ran my harness and computer through that hole to the left of your intake on the fire wall. made a clean install.
Old Nov 13, 2005 | 01:07 PM
Vader's Avatar
Precisely. The TPI and long stroke/bore 305 is just about an ideal combination for a truck that may see some duty. And with a moderate gear ratio, should get respectable mileage.
Old Nov 15, 2005 | 01:44 PM
Fastrucken's Avatar
hey S10Wildside
what throttle cable are you using for that swap. Was the one from the TBI setup long enough.
Graham
Old Nov 15, 2005 | 02:01 PM
Originally posted by Fastrucken
hey S10Wildside
Graham
We're going to use a Lokar cable and cut it to length.
Old Nov 15, 2005 | 04:29 PM
i used the stock tpi cable on mine. I think a lokar may be in my future
Old Nov 15, 2005 | 05:02 PM
Fastrucken's Avatar
SatisTraction
Did it work ok?
Also do you have another place to host your pics? I didnt get a chance to see them.
Old Nov 18, 2005 | 03:02 PM
What did you do for a Park/Neutral Indicator Switch?
Old Nov 18, 2005 | 04:10 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
IF you have it column mounted the easiest thing to do is get a reverse light switch for a Fullsize Van in the TBI era. My 1980 C10 is this way as is my 1983 G20.
Old Nov 19, 2005 | 09:36 PM
Shagwell's Avatar
Car: projects.......
A/c line for something like an 89 Buick in my K5 w/ serp belt. had to tweak one line slightly, but it came out looking factory.
Old Dec 6, 2005 | 01:45 PM
still working on that and a VSS to work with the th350.
what fuel pump are you using?
Old Dec 6, 2005 | 02:39 PM
I resolved the park ground signal using a new neutral safety switch that includes a ground source. This does not provide a ground source in neutral. Details can be found at http://www.eficonnection.com/eficonn...lectronics.asp
Here's the VSS details. http://www.eficonnection.com/eficonn...ansmission.asp
We used a 90 Camaro/Firebird TPI fuel pump, 87 K-10 tank for fuel injection applications, and an 87 K-10 sending unit. The gauge is currently not working...still looking into that.
Old Dec 9, 2005 | 10:22 AM
i8myz28's Avatar
Car: 86 z28
Engine: 355 TPI W/305 HEADS
Axle/Gears: 3/73's
FIRST GEN
hey satistraction is that a first gen camaro behind the truck in the pic..?
1984HO
Mar 19, 2021 11:59 AM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
mizz0313
Aug 12, 2015 06:45 AM
