Hot TPI system
Old Nov 23, 2005 | 10:02 PM
blackbeauty's Avatar
Car: 1989 Trans Am
Engine: 1989 305 TPI
Transmission: 700-R4
Axle/Gears: 2.77 10 bolt
Hot TPI system
Hi all,
A friend has just got his stock 88 Camaro TPI system back together and it appears to be running well. However, within moments of running the paint on the right side header just started peeling off, but the paint on the left header stayed intact.
Using a temperature reader, each header primary on the right side showed 200 degrees (celcius - I think) hotter than the primaries on the left side. The car wouldn't have entered closed loop yet, but we thought it rather odd that there would have been such a large temperate difference.
What could be causing this? Possibly bad injectors, running lean on one side? Any tips would be appreciated.
Old Nov 24, 2005 | 01:03 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: Hot TPI system
Originally posted by blackbeauty
Hi all,
You may have an exhaust leak.
Old Nov 24, 2005 | 02:03 AM
90Formula-X-F's Avatar
Car: 90 Formula
Engine: 355 C.I.
Transmission: 5 Speed
Man this is really open ended.. Lets see did we get more hand prints on that side or maybe some WD 40. If it's running good forget it. if there is a problem. You'll get a light on soon enough.
Old Nov 24, 2005 | 03:56 AM
Car: 1989 Trans Am
If there's a leak we certainly can't hear it. The temperature readings we got definitely exceeded the rating of the high temp paint which explains why it flaked off. It's just weird how one side of the engine runs hotter than the other.
Old Nov 24, 2005 | 07:45 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Vacuum leak affecting a bank.
Bad injectors more prominent on one side than the other.
Exhaust leak at head.
And on and on.
I would keep an eye on it while getting it broke in and see if it still does it?
Timing set correctly?
Is it just hotter or is the one side glowing?
later
Jeremy
Old Nov 24, 2005 | 04:15 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I am gonna suggest injectors too . one shuts down ...the whole bank does .
Old Nov 24, 2005 | 08:11 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
All of the injectors are on the same circuit.
Old Nov 24, 2005 | 08:22 PM
Car: 1989 Trans Am
That one side is just hotter than the other, not glowing hot.
My understanding from the wiring diagram is that the two banks of injectors are indeed on separate circuits, that's why there's two fuses, one for each bank.
Old Nov 24, 2005 | 08:47 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
yup ....gotta love the batch fire setup ... two circuits. Not one . I had it bite me in the *** when I was diagnosing my issues once ... bought a pulse tester and theat found the lil bugger. Made the other 3 crap out . Hardly would hold an idle ...farted through the TB the odd time ...adn any throttle input cut the motor .
Old Nov 24, 2005 | 08:48 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
nope there are two .
Old Nov 25, 2005 | 12:19 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
AIR injection working properly??
Fast355
Dec 2, 2016 06:33 PM
gta90
Sep 15, 2015 04:00 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
