MAF Swap
Old Dec 10, 2005 | 06:19 PM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
MAF Swap
I've never seen this addressed before, but I am swapping out my Bosch MAF for a new MicroTech unit. The car sputters and dies within 15 seconds of start up, do I need to reset the ECM for my car to regocnize the new MAF?
Thanks,
Eric
Old Dec 10, 2005 | 06:41 PM
BOSS 357's Avatar
Engine: 357 SBC TPI
Nevermind, I tried that and it din't work. Any ideas why my car won't accept this MAF?
Old Dec 10, 2005 | 09:28 PM
Vader's Avatar
After clearing the ECM, restarting, and having the engine die with the new ECM, are there any stored error codes? Did you check the MAF power and burnoff relays BEFORE replacing the MAF? The sensor itself may not have been faulty, just a relay or connection.
Old Dec 10, 2005 | 10:03 PM
BOSS 357's Avatar
Engine: 357 SBC TPI
Vader, I think you misunderstod my issue, although I thank you for the reply. I did not replace the ECM, just the MAF. I thought if I "erased" the ECM, it would learn the new MAF, but it din't. Everything works fine w/ the old MAF, but the new one doesn't seem to wanna co-operate. There is no idiot light on, but I have not used my Auto Xray on it to check for codes. The old sensor isn't bad and any relay associated with it are fine, it was more for "performance" as I have read the MicroTech/"Wells" unit flows more (for future upgrades).
Old Dec 10, 2005 | 10:28 PM
Vader's Avatar
It's possible you were given an incorrect or defective unit. There is another recent MAF post where someone got an analog MAF for an FM system.
Just a dumb question, but the MAF is installed with the arrow pointed downstream, correct?
Old Dec 10, 2005 | 10:33 PM
BOSS 357's Avatar
Engine: 357 SBC TPI
LOL, and I wouldn't put it past me to face it the wrong way but it is facing the right way. I guess defective may be the answer but I had hoped my bad luck had run its course. If you think that may be the only solution, I can take it back tomorrow (before the Cowboys game!!!!!!) and swap it out for another one. Is there anything else I can do? What is an FM system?
Old Dec 11, 2005 | 07:52 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
i had the exact same problem with the microtech unit. bought one when i lived in louisville, you know, where microtech is located. installed it and tried everything to get it to work and it wouldn't. i had to go buy a reman one.
Old Dec 11, 2005 | 12:12 PM
Vader's Avatar
I know, but I just had to ask, just in case. Not that I would ever do anything like that
FM = Frequency Modulated. The MAF design used on '86-'89 TPI systems generates an analog voltage signal between 0-5 VDC. The signal varies linearly with the mass of air flowing through the unit. The MAF design used on 1985 TPI and V-6 MPFI systems (both Buick and Chevrolet) generates a constant 5V P-P square wave output at approximately 50% duty cycle. That signal varies linearaly in frequency with the mass of air flowing through the sensor. The two types are NOT interchangeable, despite some claims to the contrary. The analog MAF TPI ECM has no internal provision for D/A conversion of the signal. In fact, just the opposite is true, since the analog signal that is supposed to be sent to the ECM is A/D converted for integration into the calculations. The V-6 MAF ECMs conversely have no provision for A/D conversion, and are simply counting the input frequecies after buffering and signal isolation.
I have read some claims that there are MAFs that are "universal" and will work on either system, and that kind of poor understanding of the systems and their components is frightening. That is tantamount to stating that a single cow can produce both milk AND lemonade. (HINT: If someone attempts to prove this to you, don't drink the "lemonade.")
If the original MAF works just fine in the system, there is likely nothing else wrong with relays, wiring, connections, or ducting, so there is little else you can do but return the sensor and try a different replacement.
If you have a voltmeter and/or an oscilloscope or frequency counter, you could test the output signal of the replacement unint to be sure it is either an analog or FM type. Connect the voltmeter to the 'C' termial with the sensor connected and engine running. Output votage at a normal warm idle (about 850-900 RPM) should be in the range of 750-900mV. If you are reading about 2.5VDC, the meter is averaging the 5V P-P square wave signal and trying to display its RMS value. You can verify this by connecting an oscilloscope on a scroll raster and watching the waveform. If you see something other than a relatively linear trace, you've got the wrong MAF (FM type).
Either test would give you the relative confidence to return to your parts supplier and inform them that the part in the box is not what you need, and why, so that they can go back to their supplier and inform them of their screw-up.
Old Dec 11, 2005 | 04:30 PM
BOSS 357's Avatar
Engine: 357 SBC TPI
I took the Microtech unit back and swapped in another one just like it to see if it was defective. The "new" one produced the same results (dies at idle). So after the "Wells" unit turned out to be a Bosch unit and sent back, now the MicroTech unit doesn't want to play nice with the other kids, I'm back to the original Bosch unit.....I'm just about finished trying to get "hi-flow" from a MAF. Just incase anyone wants to suggest it, I'm not gutting my MAF.
Thanks to everyone who has helped me with this issue over the last month and a half. One day I hope to be able offer beneficial advice in return.
Go Cowboys!
Eric
trevor1010
Aug 26, 2015 02:41 PM
NBrehm
Aug 25, 2015 11:49 PM
nuggie
Aug 25, 2015 01:27 PM
trevor1010
Aug 24, 2015 08:34 PM
Bert87
Aug 23, 2015 03:50 PM
