i have to drive it like it has a carb
Old Dec 18, 2005 | 08:50 PM
upandcoming's Avatar
Car: 88gta
Engine: 357
Transmission: 700r4/3000 stall convertor
Axle/Gears: 9 bolt 3.27
my 88 ta runs like crap in the morning or when it has sat awhile. I have changed o2 sensor,cold start switch,maf,tps,new fuel pump,fuel filter,chip,plugs,wires,cap,rotor,coil, but when it hits about 180 it get alot better but not perfect! help this thing is killing me
Old Dec 18, 2005 | 08:58 PM
vwdave's Avatar
Coolant Temperature Sensor perhaps?
Old Dec 18, 2005 | 09:02 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Yes, deffinately check that. Made a night and day difference on cold startups on mine.
Old Dec 18, 2005 | 09:14 PM
Car: 88gta
Engine: 357
would that not throw a code
Old Dec 18, 2005 | 09:46 PM
vwdave's Avatar
Only if the computer knows its bad. The F-Body's OBD isnt exactly sophistocated.
Old Dec 18, 2005 | 10:10 PM
my sensor was all gummed up and the wire connecting to the ecu(or whatever it goes to, not 100& sure) was half-burned, so it was connected not throwing a code, but quite useless. It kept the car COLD since it was sensing "coolant" heat (aka burning heat from the manifold)
It used to stumple badly for like 10 seconds on startup, now it starts almost like a new car.
Old Dec 18, 2005 | 10:36 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
iac
Old Dec 19, 2005 | 08:08 PM
Shagwell's Avatar
Car: projects.......
clean your IAC passage/check or replace your coolant temp sensor - if the ECU thinks its warm/cold all the time, it'll really screw w/ the tune
Old Dec 20, 2005 | 06:38 PM
Car: 88gta
Engine: 357
well I replaced the coolant temp. sensor. BIG help! It will now light up the tires. but it did not fix it. ordered a new IAC and throttle body gaskets.they shoud be here thursday. What should I use to clean the passages with?
Old Dec 20, 2005 | 06:43 PM
Car: 88gta
Engine: 357
thought maybe it could also be the mat sensor or the egr? any suggestions or those
Old Dec 20, 2005 | 07:27 PM
Shagwell's Avatar
pull the vac hose going to the egr and plug it. go for a test drive/test start. That should tell you if your egr is screwy.
Old Dec 20, 2005 | 07:55 PM
<<K-O>>'s Avatar
Car: 88 TransAM GTA
Engine: 305 LB9
Axle/Gears: Stock
I seem to have a similar problem anyone know the coolant temp sensor part number so I can one order for myself?
Old Dec 22, 2005 | 10:05 PM
Car: 88gta
Engine: 357
update.... changed the iac still did not fix the problem. when the car reaches 180 degrees it will smooth out and run decent
Old Dec 23, 2005 | 02:28 PM
b_the_j's Avatar
Car: 92 RS
try using motorcraft carb cleaner $5 at ford(yuck) dealer it is really sticky at first then runs out easy plus it is designed to be safe for specially coated throttle bodies
Old Dec 23, 2005 | 02:30 PM
b_the_j's Avatar
Car: 92 RS
did you ensure that the tps was adjusted(were they adjustable that yeaar?)
Old Dec 23, 2005 | 02:39 PM
b_the_j's Avatar
Car: 92 RS
egr valves can be held open by carbon biuld-up the computer doesn't have any way of reading this. sometimes pulling the valve and snaking the passage will help. also check your coolant by placing a volt-meter pos lead in the fluid, and the neg on a good ground on the radiator. If your coolant is producing more than 3 tenths of one volt it is bad and will screw with your CTS.
Old Dec 23, 2005 | 07:58 PM
Car: 88gta
Engine: 357
well I changed the tps and it is adjusted right on the money, the coolant thing I have never herd of.. I do however still need to change my hoses and thermostat. anybody know about the mat. sensor.
Old Dec 24, 2005 | 09:14 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
change the fuel pump relay?
Old Dec 24, 2005 | 09:36 PM
Car: 88gta
Engine: 357
did that already. I have changed just about everything.. except the egr,and the mat sensor. which is next in line.
Old Dec 26, 2005 | 08:43 PM
Shagwell's Avatar
MAt shouldn't screw w/ you. EGR could easily though. still sounds likeit's not going closed-loop soon enough. any access to a scanner?
Old Dec 27, 2005 | 05:05 PM
Car: 88gta
Engine: 357
does the egr change at 180 degrees cause when it does it smooths out and runs like it should..any suggestions???
Old Jun 9, 2007 | 09:33 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
Re: i have to drive it like it has a carb
Your EGR valve does not recieve vacuum at idle, only when the engine is under load. So at idle, it is doing nothing and should be closed.
Infested
May 22, 2018 11:56 PM
gta90
Sep 15, 2015 04:00 PM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86IROC112
Aug 17, 2015 02:00 PM
