afpr leaking
Old Dec 27, 2005 | 05:53 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
afpr leaking
i installed a accel afpr with the new diaphram and it seams to be leaking abound the mounting holes, about how tight are the screws supposed to be? anyone else have this problem?
Old Dec 27, 2005 | 08:34 PM
Shagwell's Avatar
Car: projects.......
sounds to be loose. - is it an aluminum housing? if not, does it have the little ring that reinforces where the screws go?
Old Dec 27, 2005 | 08:40 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
the original accel model i guess had a ring, this is a newer design, there is no ring, and it seems to be aluminum
Old Dec 27, 2005 | 09:02 PM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
be sure its on there flat and it shoudlnt need alot to tighten them down.
Old Dec 28, 2005 | 08:14 AM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
If you want to take it back apart you can take the housing and with a very fine piece of sandpaper/emery cloth lying on a flat surface rub the housing back and forth untill the crosshatch shows it is flat. Sounds like you just needed to tighten it somemore.
Old Dec 28, 2005 | 03:35 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
ok this piece of junk is pissing me off, if i tighten these bolts any more they are gonna snap, i broke 2 security bits already, it's still leaking
Old Dec 28, 2005 | 08:08 PM
Vader's Avatar
You'd better remove it an flatten the surface as suggested. It shouldn't take more than 15 inch-pounds to fully seat the spring can and seal the diaphragm/gasket.
If you keep tightening and break screws, you'll be removing it anyway, and it will be a lot less fun when you do.
Old Dec 28, 2005 | 09:27 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
i'll give it a try tomorrow
Old Dec 29, 2005 | 03:39 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
yeah so i sanded this piece of crap smooth, it still leaked, tightened the bolts and one ****ing snapped, nice....
i cant belive no one has had a problem with these leaking out the bolts.
Old Dec 29, 2005 | 04:40 PM
Rob Wade's Avatar
Do you know how old the diaphram is? Its possible the thing is drying out and splitting allow your fuel leakage.
Old Dec 29, 2005 | 05:13 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
Would it be possible to add a little teflon paste to the bolts? Might work.
Old Dec 29, 2005 | 07:12 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
this is an accel one, came with a brand new diaphram, i was thinking of teflon, i just dont know though, i dont want to have any fuel problems, maybe i'll send it back to summit and get a holley and see what happens, now i need a new screw, assuming i can get the broken one out of the fuel rail
Old Dec 30, 2005 | 04:38 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
ok update, i got the screw out very easily so i'm happy about that, i put the stock diaphram in with 5 bolts just like i did the accel diaphram, i ordered some screws but i was eager to try it, and walla no leaks, the accel diaphram doesnt look bad, i should be okay using the sotck diaphram with the accel housing correct? also i let the pump run for the 2 seconds and got 43psi of pressure about 45-60 minutes later it said about 31psi is that normal?
Old Dec 30, 2005 | 09:19 PM
Rob Wade's Avatar
Good deal. Its not uncommon for the fuel pressure to leak down. It should take a fair amount of time though. An hour to drop 10-12 psi isn't to bad. Keep an eye on it. See how easily it refires in the morning.
RS Reaper
Oct 17, 2018 07:52 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
