water pump question on TPI
Old Jan 1, 2006 | 06:12 PM
My1986IROC-Z's Avatar
Car: 1986 Iroc-Z
Engine: 305 TPI (used to be Carb)
You MAF guys, does your water pump have an outlet on the top of it that goes back to the heater core? If so, does the outlet have a 45 or 90 deg elbow? Thanks
Tony
Old Jan 1, 2006 | 06:26 PM
Vader's Avatar
My '86 TPI has no hose there. The outlet port where a hose would normally exits has a hex plug installed. The pump is original, and has not been altered. 49K miles - 20 years old.
Old Jan 1, 2006 | 06:34 PM
Car: 1986 Iroc-Z
Can you explain how your heater core hoses are routed please.
Old Jan 1, 2006 | 08:41 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Doesn't the 3/4 heater line run to the IAC valve under the intake?
Old Jan 1, 2006 | 09:07 PM
Car: 1986 Iroc-Z
Yup, thats one of them but what about the other?
Old Jan 1, 2006 | 09:38 PM
Vader's Avatar
Heated coolant is tapped from a port in the crossover passage at teh front of the intake manifold. It is routed via a short hose to the lower front connection on the throttle body. After being pumped through the throttle body, it exits the hose connection on the right side and travels to the heater core. After flowing through the heater core, it exits the firewall via another short hose and connects to a steel standpipe just behind the right cylinder head. The steel pipe follows the countour of the firewall to the right subframe rail, and along the right subframe rail toward the front of the engine compartment. Near the right strut mount tower, the steel pipe connects to a 26" hose that returns the coolant to the hose bibb on the radiator, just below the filler neck.
Old Jan 1, 2006 | 09:44 PM
Car: 1986 Iroc-Z
Just below the filler neck I have the small tube, I thought that went over to the over flow tank though. I understand the routing now, tomorrow I will start to re-route and make the correct lines for the TPI. I am almost done with this carb to TPI swap, maybe another 2 days and she will kick over with a new tranny, engine, and TPI :-)
Old Jan 2, 2006 | 12:06 AM
Guest
Guest
Posts: n/a
The tube isnt small, if its a small (like 1/4") tube, that is for the overflow. There's a larger, 3/4" on the radiator. You may not have that, might be the issue.
Old Jan 2, 2006 | 10:11 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
yeah what he said tony, i'm trying to send you an email, my isp is messed up or something.
Old Jan 2, 2006 | 10:14 AM
Car: 1986 Iroc-Z
86Z, got the pic, thanks. I am taking it into the radiator shop tomorrow and have them replace the plastic end cap with a TPi model with the extra inlet. Thanks guys
Tony
eightsixseven
Dec 16, 2024 01:50 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Sanjay
Aug 12, 2015 03:41 PM
Street Lethal
Aug 12, 2015 11:33 AM
