aftermarket heads
Old Jan 2, 2006 | 10:41 AM
gta_88_kicks's Avatar
Car: 1988 GTA
Engine: 355
Transmission: 700 r4
aftermarket heads
do all aftermarket heads have the holes for the cooling fan temperature switch, and the engine temperature sensor (guage overheat)?
thanks
Old Jan 2, 2006 | 11:17 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I dont know for sure, but I would say yes, if you order a head for the correct year of your engine it should be drilled accordingly.
My Trick Flow and AFR heads did.
Old Jan 2, 2006 | 09:59 PM
Shagwell's Avatar
Car: projects.......
never seen a stock-replacement( as in 23 degree) head that didn't.
Old Jan 2, 2006 | 10:01 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
my canfields didnt have any sensor ports, and i believe afr's dont come with 'em unless u ask for em.
Old Jan 2, 2006 | 11:07 PM
Car: 1988 GTA
Engine: 355
can you get heads drilled for them by a machinist if you order heads w/out them already?
Old Jan 2, 2006 | 11:08 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
probably.
Old Jan 2, 2006 | 11:31 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
thanks
Most heads do. The temp sensor fits in the same hole as the coolant fan switch. When you put the heads on either side of the block it's in the same location. No difference! You may need to buy a larger or smaller temp switch depending on the head or use an adapter.
Old Jan 3, 2006 | 04:24 PM
Shagwell's Avatar
it wouldn't take a machinist to drill the holes. just a 1/2 drive drill and a 3/8 pipe tap from home depot...
Frozer!!!
Jan 19, 2024 04:55 PM
Cornholio7979
Sep 20, 2018 02:31 AM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
ZsTransAm
Aug 11, 2015 07:30 PM
