Porting
Old Jan 9, 2006 | 03:32 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
Porting
Anyone care to reccommend a 'porting' shop? Specifically for plenum/base
and runners.....hopefully somewhere in Arizona.....Thanks ahead of time.
Old Jan 9, 2006 | 03:40 PM
brutalform's Avatar
Is it a Superram?
Old Jan 9, 2006 | 03:43 PM
'Shifter's Avatar
Car: 87 Z-28
No, SLP runners (soon), an edelbrock base, stock plenum.
Old Jan 9, 2006 | 03:49 PM
brutalform's Avatar
I dont know about the AZ area. Im pulling my S/R off in the next few days, and having it ported locally. I did get a estimate off of ExtrudeHone, for $679.00. But that was for a S/R. Your setup might be cheaper, but not by much I suppose.
Old Jan 9, 2006 | 04:02 PM
'Shifter's Avatar
Car: 87 Z-28
Hmmmmm.....Am I that far out of it, or does that just seem high?
Old Jan 9, 2006 | 04:06 PM
brutalform's Avatar
No , your with it, thats way too high. Lingenfelter wants even more for porting. Id say try Arizona Speed and Marine, but they are probably the same.
Old Jan 9, 2006 | 04:11 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
get a die grinder and do it your self, not much to it, plenty of helpful articles too.
'Shifter's Avatar
Car: 87 Z-28
Yeah, tried them first, but never get a response either live, via e-mail or
messages. Tells me what I need to know....next!
Old Jan 9, 2006 | 04:16 PM
'Shifter's Avatar
Car: 87 Z-28
It may come to that....unfortunately, unlike Mick Jagger, time isn't on my side.
Old Jan 10, 2006 | 08:42 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Look for a local maching shop with someone who does heads.
Or look for someone who just ports heads and intake.
they are there, just have too look.
Its worth it if u can find someone who will do a good job for cheap.
Other than that, do it yourself or find someone on the boards near you who can give u a hand.
Its not hard, more time consuming than anything if u havent done it before. I've done heads intakes, runners and plenums. doing a whole set with air tools and all my bits still would take me the better part of a day for what I end up doing.
Extrude hone is expensive, but I can almost promise you, that thing will flow about as good as humanly possible when u get it back.
later
Jeremy
Mark_ZZ3
May 24, 2018 01:02 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
sammy52401
Nov 11, 2015 07:20 PM
Reid Fleming
Oct 10, 2015 09:56 PM
bplessy
Sep 30, 2015 12:14 PM
