tpi runners
Old Jan 17, 2006 | 10:45 PM
2-toneTA's Avatar
Car: currently a 99 sable, and an infamous 98 4.3L 5sp S10
Engine: 220+4.3L, and a 200hp 3.0L
Transmission: 5sp nv3500, and an axn4 AT
tpi runners
Hi, I was just wondering which aftermarket tpi runners flowed the best. I have seen the slp, edlebrocks, and the accel. I just wanted to know, I will still use the factory upper plenum, and have the factory base ported. I just need to know since the engine is around 366 or so cubes. Thought I'd ask. Thank you
Andrew
Old Jan 18, 2006 | 12:00 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Between the Edelbrocks and the SLP runners, everything I have read says the Edelbrocks flow more out of the box.
I'm not sure about the Accel ones.
If I were going to buy aftermarket runners (and I am soon ), I would spend a little extra and get Long Tube Runners (LTR) from Arizona Speed & Marine or TPIS. They are supposed to provide alot more torque & HP while retaining a stock appearance.
Just my 2 cents.
If you do a search, you will find many posts regarding runners and runner/intake combos.
Hope this helps.
Best of luck!
Old Jan 18, 2006 | 02:10 PM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
EDELBROCK HANDS DOWN
Old Jan 18, 2006 | 04:34 PM
2-toneTA's Avatar
Just my 2 cents.
You have a website for these runners, I am getting a 88 Trans am on saturday. It still has a factory intake, only things not stock are the heads and internals. The engine was claimed to be high 280's with a stock tpi, so I want to find something that flows better...lol. BTW, anyone interested in a 91-2 Camaro Z28, hardtop, at, 5.7L???? Just saw it today, no idea on price...lol. Thanks again guys.
Andrew
Old Jan 18, 2006 | 05:11 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
This will give you an idea of a few runners performance
https://www.thirdgen.org/techbb2/sho...hreadid=273727
There are some flow #s for the accel here.
http://stealthram.com/flowcomparison.html
Here are the dimensions of some of the runners im sure the larger diameter ones flow more unported.
Stock TPI-------- 7.250"------1.470" round(1.70 sq inches)
SLP -------------- 6.625"------1.600" round (2.01 sq inches)
Accel LTR------- 6.625"------1.615" round (2.05 sq inches)
TPiS-------------- 7.625"------1.660" round (2.168 sq inches)
From everything I have seen the TPIS and ASM runners flow the best unported but the SLPs are capable of being extensively ported.
Old Jan 18, 2006 | 07:00 PM
2-toneTA's Avatar
About what on prices, I know I've seen the slp runners for right at $300, anyone else know of any? BTW, I want to be able to polish the runners since the upper plenum was polished by myself 2 years ago when my friend first bought the car.....that was time consuming, but made it look much better. Those TPiS appear stock you say? I may need a price on those, because I want it to look stock to tell ricers it is only the stock 305......buwahahahahahaha.
Andrew
Old Jan 18, 2006 | 09:44 PM
shaggy56's Avatar
Car: 71 Nova
These are the accel ltrs and are around the $400 through summitracing.
Ok TPIS runners will run you $475
http://www.tpis.com/
Old Jan 18, 2006 | 09:53 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Prowling around Dyno Don's shop I get to see the different intakes. Out of the box the Edelbrock units are the best.
I recently saw a set of Accels that will have a big time air leak. To much machining was done and the supplied gaskets would not seal up the gap. They will either be sent back or welded up. Quality control was absent.
Out of the box I'm not overly impressed with the SLP units. However if you are going to modify or work on the runners than that is where the SLP's shine and are the best. They have a lot of meat and lend them selves to be modified to your hearts content.
Old Jan 19, 2006 | 11:00 AM
The TPIS website is www.tpis.com
The Arizona Speed & Marine website is http://www.azspeed-marine.com
Old Jan 19, 2006 | 07:19 PM
2-toneTA's Avatar
OK, so if I am going to eventually extrude hone the runners, I should get the slp's? Do those look nice once you polish them?
Andrew
Old Jan 19, 2006 | 07:49 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Dollar for Dollar, SLP's. They can be ported to all hell. Paired with k&ns, gutted boxes and runners, it makes your intake sound gooood.
Old Jan 19, 2006 | 07:58 PM
2-toneTA's Avatar
I think they look awesome too, do they say SLP on them anywhere, like the sides of the runners? I just think that would look cool. Thanks for the advice. I just need something a little bigger for now, but will need to port in the future. BTW, how much do you guys think a 91-2 Z28 hardtop, 5.7tpi, at(white exterior, dk red int.) is worth......I'm jacking another thread....sorry.
Andrew
Old Jan 19, 2006 | 11:22 PM
Kennerz's Avatar
Car: 88 5.7 Iroc, 2000 SS
Engine: Vortec Hot cam TPI/LS1
Transmission: Pro-Built/T-56
AZS&M - highest quality out of the box - no contest TPIS = same thing for more $$
Old Jan 24, 2006 | 12:57 AM
vectra28's Avatar
Car: 1985 corvette
Engine: 383 Superram/RHS Heads
Axle/Gears: 3:07
I have a set of AS&M runners new in the box for sale if someone is interested $375 shipped. TPIS new is $495 and AS&M new is $395 plus shipping. If interested email me at vectra28@yahoo.com I waited over 6 months for these to be ready and I don't know why they take so long to make but have decided to go with the superram instead.
Old Jan 24, 2006 | 07:32 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
SLP sucks . Well stock they do . They are cisually smaller than the edlebrock ports. It's a shame though that the Edlebrock ones are so dam pricey . Check my site I got a pic of mine siamesed in 4" . They have LOTS of room for porting
Old Jan 28, 2006 | 01:24 AM
Dave Farr's Avatar
I didn't want to spend hours grinding, one rule of thumb is keep the same manufacturer for the base and runners. Since I have the Edelbrock Vortec base- I went with the runners and just ground the casting marks- all pretty pricey- keep in mind to have a couple spare sets of lower gaskets- Edelbrocks are different from GM. I learned the hard way- tighten the lower runner bolts first.
Old Jan 28, 2006 | 06:53 PM
Kennerz's Avatar
I had to grind the AZS&M runners slightly arround the bottom flanges to fit the vortec base.
Old Feb 1, 2006 | 06:16 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I love my AS&M runners. They are already extrude honed from the factory. Thats why there is a 1-2 month wait for them.
Old Feb 3, 2006 | 03:38 AM
RPOL98's Avatar
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
I have SLP runners on an Edelbrock base. the SLP runner ports line up pretty good with the manifold base even though they are different mfr.
I'm not so sure it's worthwhile to get aftermarket runners if you're keeping the stock base. the stock base is pretty restrictive, and not a whole lot of meat for grinding.
The SLP runners don't have any advertising on them. I'm happy with them.
tazs2000
Jul 15, 2017 08:44 AM
stalkier
Dec 6, 2015 11:25 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
mdtoren
Aug 23, 2015 12:52 PM
Sanjay
Aug 12, 2015 03:41 PM
