Computer Carb Return Line...
Old Jan 18, 2006 | 08:20 PM
86LG4T56's Avatar
Car: 1986 Firebird
Engine: LG4 305
Are the fuel lines for the computer carbs big enough in diameter to work for TPI? I really don't want to drop the tank unless I absolutely have to.
Thanks!
Old Jan 20, 2006 | 11:10 AM
TPI Monte SS's Avatar
Car: 1988 Monte SS
Engine: ZZ4-cammed TPI 355
Transmission: World-Class T5
The feed line is fine, but the stock return line is too small. I used the charcoal canister line instead as my return line, and then the original return line became my vent for the canister.
Old Jan 20, 2006 | 02:46 PM
86LG4T56's Avatar
Car: 1986 Firebird
Engine: LG4 305
The vent line is larger? Did you have to drop the tank and swich the connections for the purge and the return?
Old Jan 21, 2006 | 02:13 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
just put in TPI fuel lines it's real easy and alot less hassle then messing with your carbed lines, the v-6 fuel injected or TBI 305 lines are all the same as TPI save yourself the hassles and find a set of fuel injected lines
Jproz1167's Avatar
Old Jan 22, 2006 | 12:07 AM
BruceEmbry's Avatar
Car: 82 Ponitac Firebird
Transmission: 4L60e/TCI TCU
I used the original carb fual supply and returns lines when I did the TPI converion on my 82 Bird that came with the LG4 engine. Never had a problem with it getting enough gas. I am running a 350 ci engine. I use an external fual pump located in the back.
Old Jan 22, 2006 | 06:45 PM
Car: 1988 Monte SS
My Monte originally came with a carbed L69, so I'm assuming the fuel lines are the same as yours. Yes, the vent line was 5/16", and the return line was 1/4", IIRC.
Good luck!
Old Jan 23, 2006 | 09:39 PM
86LG4T56's Avatar
Car: 1986 Firebird
Engine: LG4 305
That's cool man, thanks.
pjsparts
Oct 29, 2025 06:39 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
birdman_29
Jan 7, 2017 08:24 AM
rjcme
Sep 5, 2015 01:23 PM
GeneralIesrussi
Sep 3, 2015 03:23 AM
