Finally ran her...
Subscribe
Jan 18, 2006 | 11:25 PM
she went 14.3 @ 99 mph
60' was 2.3 (it was my first time running)
bald street tires..firt run was 14.5 then the last 2 were 14.3's
shes deff got more in her...i had the timing at base 8, so i can deff change that..get some real good tires too...hopefully ill get some 13's
I was happy though, i beat an ls1 camaro, he went 14.6...but then he ran a 13.2 later on (he spun all the way through 3rd gear)
Reply 0
Jan 19, 2006 | 12:17 AM
Lmao, an ls1 did a 14.6??? Must of been a grandma driving. Nice consistant runs there. Not sure what your running under that hood...
Reply 0
Jan 19, 2006 | 01:19 AM
sounds good, my best time was a 14.88 @ 93.6 mph, but our DA that day was around 5000 feet. must be a pretty strong runnin little car
Reply 0
Jan 19, 2006 | 06:17 AM
yea the ls1 spun real real bad...and then he ran 13.2 next run lol
yea the car runs pretty good, needs more tuning and timing...and i need to get a better '60 foot (aka need to learn to drive lol)
mods:
Engine
-350 bored .30 over to a 355
-K&B Claimer Domed(popup)hypereutectic pistons
-Comp Cams Roller Cam - 224I,230E @.50/
.513"I,.520"E
-Comp Cams roller tipped rockers (1.52:1)
-Comp Cams 1.437 dia duel valve springs
-Comp Cams locks, retainers and 11/32 teflon seals
-Heads resurfaced and machined to accept cam hardware
-Ported stock cast iron heads
-Heavy duty push rods
Intake and fuel
-Ported stock TPI upper and lower intake
-K&N filters
-BBK adjustable fuel pressure regulator (35-70 PSI)
-Heddman 1 5/8" shorty headers
-Heddman 2 1/2 inch Y pipe
-3 inch custom catback with 3.5 inch chrome tips
Ignition and computer
-Taylor 8mm wires
-Accel 300+ digital ignition
-Accel performance cap and rotor
-MSD Blaster coil
-Mallory coil wire
-Mr.Gasket 160* thermostat
-Custom engine matched prom from pcmforless.com
Transmission and Rearend
-Corvette Servo
-3.73 gears
Reply 0
Jan 19, 2006 | 10:39 AM
i dont know the weather down there or the density altitude/etc...nor do i really know what my hometown track altitude.
but on a cool day i go 13.9's at 100mph and its a stock L98 with shortie headers/catback, 2800stall. 1.88-1.93 60 foots on street tires
you should have 104mph, atleast i say. big cam and ported TPI. needs more tunning and timing etc... something aint right there. also, consider a aftermarket TPI. stock TPI is chocking that thing alot. thats a big cam for TPI, but would be suitable for aftermarket larger tubed runner TPI setup.
Reply 0
Jan 19, 2006 | 11:34 AM
yea thats what im planning to do, get a set of better runners.
as far as timing goes...any suggestions? i set it at base 20 once and as far as audible knocks go, i heard nothing. But im thinking that may be alittle high...so maybe around 16 base?
my tires are bald and out of balance (the rears)...vibrates real real bad past 80mph..so im sure that wasnt helping things when i did 99mph.
It was real cold last night too so i figure if i had had good tires and got traction, i would have had some much lower times.
Reply 0
Jan 19, 2006 | 12:15 PM
I'd be suprised if you could go much past 10 base timing w/o knock. - Dans87GTA ran a 13.79 with roughly the same mods as you. -
355, KB flat-tops
ported plenum/base, airfoil
adjustable fuel pressure reg.
220/230, 497/502 hyd roller
bowl blended heads
Flowtech headers, 3" exhaust w/ Blowmaster
Ram-air hood/box/K&N
3.27 9-bolt
stock chip/tune
- the one plus, built 700r4, vette converter
he was also cutting 1.9X-2.00 60fts...
sounds good though. - work on the launch
Reply 0
Jan 19, 2006 | 05:25 PM
With radials that ls1 proably could have gotten in the 12's.
Reply 0
Jan 19, 2006 | 05:27 PM
mods:
Engine
.513"I,.520"E
Intake and fuel
-K&N filters
-Taylor 8mm wires
-MSD Blaster coil
-Mallory coil wire
-Corvette Servo
-3.73 gears
Those ported stock heads has got to go. Throw them over the fence. Trick Flow heads will put you into the 12 right out of the box with an aftermarket base & runners and 52mm TB.
Reply 0
Jan 19, 2006 | 05:38 PM
heads/cam/intake make your hp, the rest you just build to stay together...
Reply 0
Jan 19, 2006 | 07:29 PM
yea i know, i was just on a budget...most of the work was already done to the car when i got it.
the car needed alot...motor and body work wise. So i didnt really focus too much on the engine..i figured it had a good amount of power as it was. Now i need to work on the body..its ugly as sin. So maybe later on ill grab a new set of heads and what not.
Reply 0
Jan 19, 2006 | 07:55 PM
AHH!! too much lift for your tpi.
You have atlleast .4 in your 60 ft alone. Go Carb and run 13 flat.
Reply 0
Subscribe
