Another 305 Cam question.....
Old Jan 24, 2006 | 09:51 PM
95Cam86Roc's Avatar
Car: 86 Iroc
Engine: LS3
Before anyone flames about not using the search button, I'll let you know that i spent the last three hours reading about cams for the 305 TPI and cams in general. I have read and read but still have no idea on what cam to get for this motor. If my budget wasn't so tight i would get a 350 but being in college i can't afford that.
So enough said i need to know what the best cam for a 305.
The motor is completely stock as far as i know. Although i do have headman shorty headers that will soon be going on.
I was told that these two cams are good choices:
PBM- 290 Duration, .465 Lift
Comp- 260 Duration, .480 Lift
My plans for this motor are the headers, bigger cam, port the pleneum and runners. I'm sure there is more to do but i have no idea.
BTW this is not a daily driver but i do drive it at least three times a week.
If anyone can help me i would greatly appreciate it since i am completely new to this.
Old Jan 24, 2006 | 10:07 PM
86camaroguy's Avatar
Car: 86 iroc-z
Engine: 305tpi
i have the exact same car and motor and i was told to use a lunati cam and lifter set look on summitracing.com part number
lun-00016lk thats what i ended up getting will be going on next weekend they sell them new as a kit for $136
Old Jan 24, 2006 | 10:13 PM
95Cam86Roc's Avatar
Car: 86 Iroc
Engine: LS3
Thanks for the info. Will you let me know if it make much difference.
I already have a 3in exhaust with duals but its duals from the muffler back. If that matters.
Old Jan 25, 2006 | 11:50 AM
Shagwell's Avatar
Car: projects.......
260 or 290? must be "advertised" duration numbers. - The biggest thing you need to look at is @.050 duration. Stay around/under 225, look for around 480 lift. Go dual pattern w/ stock heads(i.e 214/220@.050, 480/484 , not 214/214, 480/480) you'll like the results. - also I noticed your car is an 86. should be flat-tappet, not hyd roller. Makes cams much cheaper...
Old Jan 26, 2006 | 11:08 AM
95Cam86Roc's Avatar
Car: 86 Iroc
Engine: LS3
If anyone else has any input or suggestions please let me know..
Old Feb 26, 2006 | 01:01 PM
JDubya18's Avatar
Car: 86 Camaro IROC-Z
Engine: 305 LB9
Id like to see some more suggestions
Old Feb 26, 2006 | 03:23 PM
high c's Avatar
Car: 86 iroc
Engine: yea it has one
Transmission: yea it has one of them also (im 2 for 2) :)
summit tpi cam (the one that comes with cam/springs/lifters)
Old Feb 27, 2006 | 03:08 PM
Extinct86's Avatar
Car: 1986 Pontiac Trans Am
Engine: LB9
Transmission: TH-700R4
Axle/Gears: 2.77 Posi
Do you have a part number for the Summit cam?
Old Feb 27, 2006 | 03:16 PM
<<K-O>>'s Avatar
Car: 88 TransAM GTA
Engine: 305 LB9
Axle/Gears: Stock
SUM-G5000 Summit TPI Cam and Lifter Kit
Old Feb 27, 2006 | 04:28 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
My cam is 214/224 @ .050 lift and .442/.465 lift. I would not go much larger than this on any TPI 305. carb'd may be a different story but for a 305 with a long runner intake setup like TPI, I would not go any higher than what I have, as a matter of fact if I had it to do over again I would run just a tad smaller duration.
Old Feb 28, 2006 | 12:20 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
That Summitt cam listed above is a bit on the small side.
Take a look at this Lunati cam avail from Summitt: LUN-60101LK
$190 with lifters inc.
Old Mar 1, 2006 | 08:51 AM
V6camaroman's Avatar
being that your keeping the tpi i would personaly run the comp cams xe256 cam. keeps power between 1200 and 5200rpm. its the cam im currently running and it makes great power and doesnt cause driveability problems. you could get away with the xe262 though with minimal problems
Old Mar 1, 2006 | 11:21 AM
mnorton's Avatar
Engine: 305 LB9 TPI
I think that Comps XE256H-12 would be a very good cam for a stock 305.
Old Mar 1, 2006 | 12:05 PM
Shagwell's Avatar
I wouldn't go larger on duration, but more lift than that would be nice.
Old Mar 1, 2006 | 12:20 PM
mnorton's Avatar
Engine: 305 LB9 TPI
More lift won't do much (if any) good on stock heads.
Old Mar 5, 2006 | 02:42 PM
91tpiTA's Avatar
Car: 91 T/A, 79 T/A
Engine: 305 TPI, '68 350 Olds SC'ed
Transmission: 700r4, 350 Streetfighter
Axle/Gears: stock, 3.42
Ok, so what kind of cam would you suggest for my '91 305 TPI? It is stock besides I have a better intake, a set of 113 aluminum heads and A/C deleted. Car has 70,000 miles. Would any of the cams listed above work good for my setup or would a different one be better? I never understood durations and lift numbers of cams. I'm boggled when it comes to cams.
Jake_92RS
Jan 28, 2020 10:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
beastin91rs
Oct 9, 2015 07:38 AM
michealleger
Aug 26, 2015 03:29 PM
theurge
Aug 21, 2015 12:46 PM
