poor idle 5 speed swap
Old Jan 26, 2006 | 08:20 PM
IROCBMX's Avatar
Car: 1987 IROC-Z
Engine: 2002 LS1
Transmission: 2002 T56
Axle/Gears: fabricated 9" w/ 4.11 gears
I recently swaped out my 700r4 tranny for a T5 5 speed, in my 87 iroc-z with a TPI 350. As soon as I was finished with the swap the car has been idleing very poorly. It idles very low and jumps around, as if the car is trying not to stall. The car runs fine when I am driving it. I was wondering if I need to get a new prom for a 350 with a 5 speed. If anyone could help me I would appriciate it.
Thanks,
John
Old Jan 26, 2006 | 09:00 PM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
Frst thing I would do is look for a vacuum leak, maybe you knocked a line of or something like that while you were working. Also you might need to reset your minum idle setting since yours was set up for an auto.
Old Jan 26, 2006 | 09:45 PM
IROCBMX's Avatar
Car: 1987 IROC-Z
Engine: 2002 LS1
A vacuum leak was the first thing I thaught of too, but I did not find any. How would I go about reseting my minum idle setting.
Old Jan 28, 2006 | 05:00 PM
meridius's Avatar
heres the tech article that explains it all https://www.thirdgen.org/newdesign/tech/tpimod2.shtml
Old Feb 2, 2006 | 06:15 AM
IROCBMX's Avatar
Car: 1987 IROC-Z
Engine: 2002 LS1
sorry it took so long to reply, I haven't found the time. Thanks for the advice, this weekend I will get a chance to reset the idle air control, and i will let you know how it turns out.
Old Feb 2, 2006 | 05:40 PM
Shagwell's Avatar
Car: projects.......
you did get the neutral switch hooked up properly right??? and the speedo? if not the computer doesn't know whether you're moving/stopped, in gear or not...
Old Feb 2, 2006 | 07:19 PM
joeyg329's Avatar
Car: 88 iroc/383 82 regal/sonoma 4.3 5sp
Engine: 5.7 tpi/383/4.3
Transmission: 700r4,th350,t-5
does the speedometer need to be working right for the computer?? my speedo is like 12 mph off because i changed the gears... will that affect anything in the computer?
Old Feb 3, 2006 | 04:57 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
My car ran fine with the auto prom after my T5 swap. I burned a new chip set for a manual for the hell of it and it still ran the same.
Old Feb 5, 2006 | 09:55 PM
Shagwell's Avatar
- It'll run fine w/ the speedo reading wrong, mostly I was saying it needs to read. - It's better to be calibrated correctly, but it's not gonna make a noticable difference. - and yes, it should run fine, I'd say probably something's not hooked up properly. The computer needs all the inputs it supposed to have to function properly.
Old Feb 7, 2006 | 06:07 AM
IROCBMX's Avatar
Car: 1987 IROC-Z
Engine: 2002 LS1
my speedo runs just fine, and this weekend I tried reseting my minimum air idle setting, and it still idle poorly. the car actually died a few times, so I had to turn the idle up a bit just to keep it running. I can get it to idle smoothly between 1000 and 1500 rpms, but that is way to high. Next I will have to check my tps.
Old Feb 9, 2006 | 04:11 PM
Shagwell's Avatar
somethings got to be amiss...sure you didn't mash any wires between the bell and the motor or anything like that?
Old Feb 9, 2006 | 08:00 PM
IROCBMX's Avatar
Car: 1987 IROC-Z
Engine: 2002 LS1
I am prity sure that i didn't smash any wires, but this weekend i will have to give the whole motor a full over view to make sure.
InfinityShade
Aug 22, 2015 08:00 PM
jbd1969
Aug 17, 2015 07:06 PM
perZ
Aug 15, 2015 01:17 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
