Cam feedback
Old Feb 2, 2006 | 02:57 PM
mantiz85ws6's Avatar
Car: 85 Trans Am
Engine: 350 T.P.I.
Transmission: WC T-5
Cam feedback
Ahttp://store.summitracing.com/partdetail.asp?part=CRN%2D114122_&N=115_&autoview=sku
anyone using this cam?? Any comments /suggestions??
Old Feb 2, 2006 | 03:21 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
It looks like it'll run out of breath at 4500 rpm. Keep lookin'...
Old Feb 2, 2006 | 03:32 PM
Car: 85 Trans Am
Engine: 350 T.P.I.
I talked to a tech at summit and he said that the numbers listed are just the base numbers and the cam would pull to 5200 no problem.
Old Feb 2, 2006 | 03:42 PM
mnorton's Avatar
Engine: 305 LB9 TPI
I'd look for a little more lift and duration.
Old Feb 2, 2006 | 04:24 PM
Car: 85 Trans Am
Engine: 350 T.P.I.
Any cam in mind that you can recommend?
Old Feb 2, 2006 | 04:52 PM
mnorton's Avatar
Engine: 305 LB9 TPI
How about this?
http://store.summitracing.com/defaul...+-59098+-42273
Old Feb 2, 2006 | 04:54 PM
mnorton's Avatar
Engine: 305 LB9 TPI
Sorry, my link is hosed.
Search for this cam/lifter kit
LUN-01003LK
Old Feb 2, 2006 | 05:15 PM
Car: 85 Trans Am
Engine: 350 T.P.I.
This is the cam I am currently running but I was told by Summit technical services that the lobe seperation was too tight and it wasn't computer compatable. The Tpi cars like an LSA of 110-114?
Old Feb 2, 2006 | 05:18 PM
Car: 85 Trans Am
Engine: 350 T.P.I.
That link is junk too!! Look up part number ISK-201264.
Old Feb 2, 2006 | 09:01 PM
mnorton's Avatar
Engine: 305 LB9 TPI
Is there a problem with how the engine runs now?
That Isky cam looks to be pretty mild to me, and I'd think would be better than the stock cam if used with stock heads.
TPI does like LSA of 110-114
Old Feb 2, 2006 | 09:42 PM
Car: 85 Trans Am
Engine: 350 T.P.I.
The engine runs fine, but my emissions HC and CO counts were high so I am trying to figure the problem out.
Old Feb 2, 2006 | 09:55 PM
mnorton's Avatar
Engine: 305 LB9 TPI
"Comp Cams has a computer-friendly grind that works well with the TPI and MAF. Call them and ask about the 260AH-14 grind in your application. It specs at .444"/.444", 212°/218°, and 114° LSA."
268AH-14 looks like a good choice for a non-stock setup.
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
Strick1
Sep 4, 2015 07:11 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
