no start when warm
Old Feb 6, 2006 | 05:18 PM
joejoe's Avatar
Car: red one
Engine: on the floor
Transmission: next to engine
Axle/Gears: the ones that turn
no start when warm
I have a 86 Z was 305, now 355 roller. The motor is brand new, the censors are old & for a 305.
will a knock censor for a 305 (not 350) cause the no start when motor is warmed up?? motor will start fine when cold, but after warm up, it will not start , untill cooled.
if more info is needed let me know.
joe
Old Feb 6, 2006 | 07:15 PM
Drew's Avatar
A bad knock sensor will cause a SES light, its not responsible for your no start.
Why don't you post a few more details of what's happening when it doesn't start? Does the engine crank at all? Starter make any noises? If the starter doesn't turn over, have you tried rapping on it a couple times with a stick or a hammer? They tend to get hot and not kick in properly. If that's all it is, replace the starter.
Old Feb 6, 2006 | 07:54 PM
joejoe's Avatar
Car: red one
car will start (will not idle w/o foot) after heat up car will idle (surging a little) if you turn motor off, starter will turn motor freely
has good spark at plugs, and injectors (at the no start time)
I also have a code 33 (have new EGR & sencer, just have not put it on yet)
Old Feb 7, 2006 | 04:22 PM
joejoe's Avatar
Car: red one
anybody??
somebody has had to have run across something like this.
joe
Old Feb 12, 2006 | 07:29 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I had a similar problem with my L98 TPI engine. Turns out one of the injectors was bad and when it warmed up, it went to ground and pulled the other injectors with it, causing them to dump fuel. Car did not want to start when warm and when it did, it ran pig rich. I remember I had the car at a friends house in Savannah GA and had to get home to Jax FL. When I finally got home, I swear the plugs had no gap! I think the MSD box was the only thing keeping the car running. Not sure if this is your problem but this problem kicked our butts for weeks.
Old Feb 13, 2006 | 12:04 AM
joejoe's Avatar
Car: red one
thanks, I will check the injectors when the no start happens.
thanks for the post. joe
Old Feb 13, 2006 | 02:45 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Defintiely ohm the injectors, seen what he said a lot more than once.
Anything under 12 ohm is junk according to GM(may or may not tell the whle story, but if still stock, it prolly will)
Bad temp switch could do this too.
Ignition parts are another good thing to fail under heat as well.
The pick up coil and ign module jump to mind.
Also, u never mentioned if it cranks or not. If it doesnt crank hot your solenoid is going bye bye.
later
Jeremy
Old Feb 13, 2006 | 06:50 PM
joejoe's Avatar
Car: red one
motor cranks fine, good spark at plugs, and injectors.
thanks to all that posted. joe
Old Feb 19, 2006 | 07:14 AM
IROC HeRbZ's Avatar
Car: 1987 IROC-Z
i think i'm experiancing something simular to this... any updates joejoe?
Old Feb 19, 2006 | 09:16 AM
bnoble's Avatar
Car: '91 Firebird Formula
Engine: 383 w/ BW S400 turbo
Transmission: TH400
Axle/Gears: QP 9", 35 spline, spool, 3.15:1
I assume you swapped out your old prom when you dropped in the new engine? If your crank pulsewidth values aren't matched to your new engine and larger injectors, you might be running too rich at startup, which is especially noticeable when warm. Hold the gas pedal to the floor to enable flood clear mode and see if it starts.
Old Feb 19, 2006 | 03:40 PM
TexasB4C's Avatar
Car: 92 Camaro B4C 350
just for my own info what makes the solenoid not work when its hot? just something ive been wondering about
Old Feb 20, 2006 | 06:06 PM
joejoe's Avatar
Car: red one
no updates yet!?!??
Old Feb 20, 2006 | 06:13 PM
joejoe's Avatar
Car: red one
Bnoble: still no start
TexasB4C: heat expands cracks, or will open a cracked wire.
Old Mar 1, 2006 | 09:23 AM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
Gounds on the back of the head clean and tight? Make sure you don't have any paint on the ground stud.
What do your plugs look like when it is running?
Can you verify the injectors are firing when you have the no start condition? Have someone crank the engine over, and place your fingers on the injector bodies. You should feel them clicking very rapidly.
Old Mar 1, 2006 | 10:13 AM
Vader's Avatar
Are you still using the 305 (19#) injectors with the 355? If so, the start fuel with a warm CTS may be inadequate. You need to install 350 (22#) injectors and a 350 calibration (PROM) or reprogram what you have.
Old Mar 1, 2006 | 02:20 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
My 353 ran great with the stock 305 prom APYS ( but I had 22lb injectors) . Now I have the corvette bin ( APYP ) and I have idle issues .
Change that knock sensro over to the 350 one for starters . Sounds like possible injector thing ...or that CTS sensor.
Did you ohm them out yet ?
Old Mar 1, 2006 | 05:31 PM
joejoe's Avatar
Car: red one
I think its a bad temp switch. and I also have a sensor kit comeing from TPI parts.com. (all sensors are 20 yrs old)
VADER: it dose have #22 SVO injectors and a hypertech for 350 TPI (you are right about needing a new chip)
92 blue: all grounds are clean & tight
D's89IROC: injectors are brand new, but will check.
joe
Orr89RocZ
Apr 25, 2016 08:28 AM
CORV3TT3
Aug 23, 2015 11:26 AM
stalkier
Aug 13, 2015 12:59 PM
mustangman65_79
Aug 8, 2015 12:07 PM
