vacumm line from plenum
Old Feb 26, 2006 | 12:27 PM
graphicideas1's Avatar
i cracked a vacumm line from the passanger side of the plenum that runs in a wire harness along the fire wall - i can net get to it to fix it - what does this control? It goes in the same wire harness as the one coming off the "heater valve"
Old Feb 26, 2006 | 12:32 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
not 100% certain, but i think that's the one that goes inside the car for the heat/ac controls...
Old Feb 26, 2006 | 12:36 PM
what if i leave it broke?
Old Feb 26, 2006 | 10:51 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
fix it/ plug it because it is a vacuum leak. will cause a lot of weird problems with your engine performance.
Old Feb 27, 2006 | 11:04 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
they do make plastic connectors to fix those. Just call the autoparts store.
Old Feb 27, 2006 | 11:15 AM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
yeah man it looks like a sleeve it just goes over the hose and connects the 2 broken ends, i've done that a million times haha
Old Feb 27, 2006 | 03:58 PM
Duts87ss's Avatar
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
You can use just a regular piece of rubber hose to slip both sides into.
Old Feb 27, 2006 | 04:00 PM
i got it but it broke so far down the firewall it took a hour to get to - thanks
Old Mar 1, 2006 | 10:39 AM
bigchief's Avatar
ohh man, thats not fun. good job though, congrads! that can be pretty darn annoying D:
tyeo098
Nov 30, 2015 06:27 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
85 Jimmy
Sep 30, 2015 07:56 AM
TBRays98
Sep 6, 2015 05:05 PM
