Cold Start Deletion Question
Old Mar 3, 2006 | 03:49 PM
Duts87ss's Avatar
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
I have '86 TPI setup with harness to install on my Monte. I wanted to delete the cold start injection; so I bought a set of '89+ runner and fuel rail to keep from having to block any of the CSI stuff off. Do I need to use a '89+ throttle body now so that the engine gets idle air?
I did some searching, but couldnt come up with a direct answer to this question.
Thanks.
Old Mar 4, 2006 | 06:09 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Duts87ss,
i don't think you will need the later throttle body as long as you keep the '86 plenum but i am not sure. hopefully someone can give you a more definitive answer.
would you be willing to sell the cold start injector and the extra set of fuel rails you have? LMK if so and how much.
Old Mar 4, 2006 | 06:49 AM
Kwiksilverz28's Avatar
If you don't have a leaking injector, all you really have to do is unhook the electrical connectors from the CSI, and change PROMS. I did that for a few months untill I ripped the TPI apart to rebuild it. Then I did the SLP runners and did a home brew fuel rail block off.
You do not need to change the throttle body.
Old Mar 4, 2006 | 07:45 AM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
I'm not using the CSI on my setup with the 86 TPI setup and eliminated the CSI in the prom
Old Mar 4, 2006 | 08:05 AM
Duts87ss's Avatar
Did you update to late model (89-92) runners from SLP?
Old Mar 4, 2006 | 10:13 AM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
I had the hole for the CSI welded shut for both my SLP & stock runners
Old Mar 4, 2006 | 12:32 PM
Duts87ss's Avatar
The later model runners didnt have an air tube for the driver side; so I'm wondering if I'll have any idle air when using the early TB and late runners.
Old Mar 4, 2006 | 10:03 PM
Duts87ss's Avatar
I'm thinking I may just have the '86 TB I have machined to match a '89+ TB. I'll take a '89+ TB gasket and machine out the area where the gasket is open.
Old Mar 5, 2006 | 07:15 PM
I have a 88 Throttle body, 88 plenum, 88 fuel rails, newer type SLP runners.
Old Mar 5, 2006 | 09:40 PM
Duts87ss's Avatar
No idle problems?
Old Mar 5, 2006 | 11:27 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
I have '88 TPI intake, blocked CSI port, plugged fuel rail, I'm using a '89 Corvette ARAP bin.
I also bored out the '88 TB with an air foil installed to 52mm, and deleted the TB coolant system.
No idle problems. The idle is higher than stock, but that's because of the cam & stroke.
Old Mar 6, 2006 | 08:01 AM
Duts87ss's Avatar
Are you using '89+ runners?
Old Mar 10, 2006 | 08:07 PM
Originally posted by Duts87ss
No idle problems?
Not at all. Knock on wood, runs perfect. Just need to get the suspension all straightened out, and will be perfect.
Old Mar 11, 2006 | 12:11 AM
Duts87ss's Avatar
Thanks, that'll keep me from having to get the TB machined.
Old Mar 11, 2006 | 01:38 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
The only induction part that's not '88 is the Scroggins Dickey High-Flow TPI Vortec lower intake base-plate.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
apie2546
Aug 10, 2015 05:43 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
