Biggest cam with Cali emission?!
Old Mar 11, 2006 | 09:33 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
I was thinking about the comp 220/230. Do you guys that I can pass the sniffer with that stick? It would be tuned, heavily, quite possibly detuned to make sure it passed. When I get the car running I will also be looking into some realtime emulation stuff. But what do you guys think? Anyone running a similar cam with good results as far as smog? I was gonna go with a LPE 219 but decided to go a little larger. Thanks guys
Will
Old Mar 11, 2006 | 09:44 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
You should have no problem with the proper tune. We have guys in our local club with bigger cams passing smog with flying colors.
Old Mar 11, 2006 | 10:28 PM
norcalz28's Avatar
Sweet
Old Mar 12, 2006 | 12:19 AM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Yep! Check out my sig below. I live in Southern California.
Old Mar 12, 2006 | 12:24 AM
norcalz28's Avatar
How do you like those heads? I was thinking about a smiliar setup to yours. 224/230 with dart heads on a forged 355 bottom end. ported TPI.
Will
Old Mar 12, 2006 | 12:49 AM
VincentZ28's Avatar
They work fine for me. Just the exhaust was ported. If I were you, I would go with the 230-238 .113LSA XFI Comp Cam to make some real hp over the 224-230. Just get a good tune and you'll be fine on passing smog.
Old Mar 12, 2006 | 01:00 AM
VincentZ28's Avatar
Here are the numbers my car did when it passed smog.
Old Mar 12, 2006 | 12:50 PM
norcalz28's Avatar
That is amazing. Actually the biggest I think I would go would be with your cam. I don't want to push it. My car is being built for a fun weekend cruiser that will catch alot of other cars off gaurd and give them a good run for their money. If I can get into the high 12's to mid 12's, that is plenty fast for me. BUt thanks for all the info. Your car runs excellently clean!
Will
Hotrodboba400
Dec 10, 2019 07:07 PM
89fast5oh
Sep 8, 2015 09:55 AM
TBRays98
Sep 6, 2015 05:05 PM
L0tuS
Sep 4, 2015 11:16 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
