suggestions for a cam
Old May 20, 2006 | 04:39 PM
INTIMIDATOR Z's Avatar
Car: 1987 IROC
Engine: Turbo 293ci 4.8l
ok well i got a 85 vette tpi motor and i wanna put a mild cam in it.
what would you guys suggest?
Old May 20, 2006 | 07:05 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
comp cams 12-262-4....
Old May 20, 2006 | 07:26 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
mild ? ZZ4. Its pretty cheap, and is a near perfect match to the TPI setup. Will work on stock MAF tunes as well.
Old May 20, 2006 | 09:49 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
i would also suggest some roller rockers
Old May 20, 2006 | 11:18 PM
MattODoom's Avatar
Car: '88 G T/A
Yep... im running 1.6 roller on the intake and 1.5 on the exhaust. specs out at .505/.510
Old May 21, 2006 | 10:02 AM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
Being that your motor is a 1985 engine, the ZZ4 cam will not work without spending alot of $$ on retrofit roller lifters, pushrods, reinforced timing chain cover and a cam button.
Old May 21, 2006 | 10:50 AM
MattODoom's Avatar
Car: '88 G T/A
Good eye, I totally missed the whole 85 part :/
Old May 21, 2006 | 11:26 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
crane makes some smog legel cams for the tpi they sale them in summit.
they look really nice.
junkcltr
Aug 2, 2019 11:12 PM
transamgta87
Sep 1, 2015 07:07 PM
camaro71633
Sep 1, 2015 10:24 AM
InfinityShade
Aug 22, 2015 08:00 PM
drathaar907
Aug 6, 2015 04:20 PM
