open element K&N for SD Firebirds
Old May 25, 2006 | 10:32 PM
F&Ybodlover's Avatar
Any of you guys using just a K&N in place of the air canister on 90-92 Firebirds? Do you know which filter it is? I had a SLP cold Air I took off my GTA 4 years ago o save for a rainy day,but it got "thrown out" I eventually plan to get a dual SLP,(If I can find one) but want to go the cheap route and just ditch that crap canister.
Old May 26, 2006 | 05:20 AM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
I have a camaro but I used a K&N RC 5000 filter. I have a speed density setup and I think it looks good.
Old May 26, 2006 | 12:39 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
We have one on the '46, looks nice!
Old May 26, 2006 | 12:47 PM
robert1's Avatar
I've also used the RC 5000, with no problems for many years. Hey Matt, that engine looks nice! Is that one of those Sanden AC systems?
Old May 26, 2006 | 01:02 PM
I guess I could go out and measure the opening, where it meetsthe canister, but I think it's smaller than the throttle body opening.It's also round not oval.
Old May 26, 2006 | 01:21 PM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
yea i ordered the 5050 1000cfm one, and i just came in from putting it back on the fedex truck...way too wide, it didnt clear the a/c bracket. So i sent an exhange for the 5000 one.
Old May 26, 2006 | 01:40 PM
MattODoom's Avatar
Car: '88 G T/A
It is a Vintage Air system, the compressor is indeed Sanden.
Old May 26, 2006 | 02:10 PM
85C4's Avatar
Car: whatever has the most gas in it
Engine: GM v8
Transmission: Uumm that's contingent
Axle/Gears: See prior line
THose are junk, they take in too much hot air. We picked up 4 tenth on my friends vette when we extended the air intake to the front of the rad.
Old May 26, 2006 | 06:00 PM
the filter I'm talking about goes directly on the bottom of the intake track, in place of the canister.The opening measure 4X4 inches.
Old May 26, 2006 | 07:05 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
On the speed density trans ams, buy a k&n air filter for a 2003-05 GMC Envoy or chevy trailblazer. Ditch the entire factory air canister and connect the air filter to the intake tube. it is the same hieght as the factory air can.
Old May 26, 2006 | 09:23 PM
thanx,will order one tomorrow
Old May 30, 2006 | 09:26 PM
picked one up at advance, Part # 1009 for $63.78 with tax. I had a brand new purolator in there, but It does seem to pull a little more out on the highway. Feels about the same when I put the $200, and more PITA to install SLP cold air on my GTA, and a little better than a $35 K&N inside the canister. Sound a little different as well. It's not a super tight fit,(I can lift it off pretty easy if I try) but it seems to be good enough. Here's a pic installed. Give it
Old May 30, 2006 | 10:23 PM
MattODoom's Avatar
Car: '88 G T/A
I thought one of the big advantages to changing the intake tract was in replacing the flat rubber elbow.... so why not just make a 3" pipe with a cone on it?
Here's mine:
Old May 30, 2006 | 10:56 PM
You have a MAF car, you can attach a 3 inch pipe to the end of your duct, SD cars have a different duct and can't. You have to replace the whole duct, which you have to get fabricated, is an expense, and probably shows little gain on a stock motor like mine.
Old May 30, 2006 | 10:58 PM
MattODoom's Avatar
Car: '88 G T/A
MAF car intake elbows are not hard to come across. As you can see I cut one up to make the joint for my intake.
Id think you could find a MAF intake elbow and put a 3" pipe in the end of that for pretty reasonable.
Old May 30, 2006 | 11:48 PM
robert1's Avatar
Matt, where did you get the 45 degree-looking black plastic piece?
Old May 30, 2006 | 11:52 PM
MattODoom's Avatar
Car: '88 G T/A
Thats 3" exhaust piping with a miter joint (about 45deg, yes) painted with black crinkle paint.
Old May 31, 2006 | 12:31 PM
yeah, you can do that on a SD car, but I really don't think it would be any better than what I did, and it's a little more $,and PITA looking for a MAF or LT1 elbow, then getting a pipe cut,painting etc. Plus, the filter I have is basically in the same spot, and is somewhat bigger, and don't larger filters flow more? I would love to see a dyno comparison of all the different cold air options for these cars though.
Old May 31, 2006 | 04:23 PM
MattODoom's Avatar
Car: '88 G T/A
I doubt your filter is bigger then mine. Yours is vertical and about the same height as the intake can oiginally was, right? Mines not conical, its a cylinder and its more then a foot long. I took the charcoal can out, it extends all the way across that area and sits right in the hole in the fender where the air comes in.
Old May 31, 2006 | 06:44 PM
you might have the same filter then, couldn't tell in your pick(part #1009?) I've seen cars with a small conical attached to the 3 inch pipe.
Brinkkl2000
Aug 4, 2018 08:29 AM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
Dialed_In
Aug 20, 2015 01:45 PM
wruiz
Aug 13, 2015 09:07 PM
