Cam Selection Need some Help
Old Jun 7, 2006 | 01:15 PM
PonyKiller87's Avatar
Car: 87 Iroc Z28
Engine: 355 TPI
I'm trying to do a little planning for my next project. Im planning on building an sbc 400 with vortec heads, SDPC base, AS&M runners, ported Plenum and bigger TB. I was looking at Comp Cams because thats what I have in my 350 now Im pretty happy with it. From what I can tell a 8-467-8 is about the biggest cam they make to work with a TPI motor. Yes I know it will need tuning, I have the stuff to do that. I just want to know if this is a good cam to use or if there is something better? I would prefer to stick with Comp.
Old Jun 7, 2006 | 02:17 PM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
well, what are the specs on that camshaft? i'm planning on using a voodoo lunati cam that has 230 duration @ .050 and about 500 lift on my TPI motor, just trying to decide on an intake and a pair of heads to go with it.
Old Jun 8, 2006 | 09:27 AM
Car: 87 Iroc Z28
Engine: 355 TPI
Comp Cams 8-467-8
Duration is 230 @ .050
with 1.6 rockers the lift is .576 In .570 Ex
the LSA is 113 deg
Old Jun 8, 2006 | 10:15 AM
HD4mula's Avatar
Originally Posted by PonyKiller87
Comp Cams 8-467-8
the LSA is 113 deg
I guess this is the XFI cam, yes? I have searched a lot here and all I heard is good things about the XFI cams as they are designed for FI. I plan to use the 466 myself in a 355.
Old Jun 8, 2006 | 12:02 PM
Car: 87 Iroc Z28
Engine: 355 TPI
Yes it is the XFI, I was looking at the 466 myself because it has the lower rpm range and "good torque" I guess thats why Im asking, Im not entirely sure what I would like to go with. I want something that will still have alot of nuts off the line but still make power up high
Old Jun 11, 2006 | 10:24 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
a 400 is abit big for a tpi.
but the cam sounds good, a smaller cam wounldnt hurt.
Old Jun 12, 2006 | 08:37 AM
Car: 87 Iroc Z28
Engine: 355 TPI
Yes I realize a stock TPI will choke a 400, thats why Im going with the new base, bigger runners and TB. Everything will be ported as much as possible. I can handle having the motor put out slightly less than a stealth ram as long as I can keep the TPI look.
Old Jun 12, 2006 | 08:35 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
cool, i like the tpi look as well. that will be a torque monster.
i myself will be biulding a 383 tpi iam shooting for all motor high 11s
iam going for a stock look that will beat LSx motors.
Old Jun 13, 2006 | 08:53 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
I read in a hot rod mag that Comp Cams has a program you can buy for $10 that lets you pick motor, intake, etc... shows recommended cams and hp / tq numbers... and also gives you the part number to order from them.
Rafael
Old Jun 15, 2006 | 03:49 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Rafael
Not sure about that.
But any one have any ideas? I called Comp Cams, Crane cams, and ISKY.
Who else can I call?
Ive got alot of #'s....but im still pulling my hair out.
Crane seems to be the best so far. intake 452 exhaust 465
The cam # is 104224
But...........I dont know.
Old Jun 15, 2006 | 11:33 PM
ZEEYAA's Avatar
Car: 1991 Z-28
Engine: 383 / TPIS MINI RAM
Transmission: 700-R4
Axle/Gears: MOSER 9IN 3.89
Sometimes you just have to take the plunge, I purchased an XFI cam for my 383 that is soon to be in the car. I cant waite, I think you have put alot of thought into it and done your research, now just make the decision and let it roll.... GOOD LUCK.
Old Jun 16, 2006 | 09:49 AM
Car: 87 Iroc Z28
Engine: 355 TPI
The cam # is 104224
That seems like its pretty small even for a 305.
I also agree, you can research as much as you want but eventualy it just comes down to a choice.
In my case I think I will eventualy go for the 8-466-8 because the low end torque it more important to me than the top end power.
Old Jun 18, 2006 | 05:38 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
lol well stock is only 350/384....so it will make a big difference I think.
Jorlain
Oct 8, 2015 01:57 AM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:14 PM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:13 PM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
