Misfire HELP!!!!
Old Jun 21, 2006 | 11:30 PM
blackz281le's Avatar
Car: 91 Z28 1le
Engine: 5.7 350 TPI
Misfire HELP!!!!
first i have a 91 350 tpi
it is rough in idle and in low rpms
cylinder 5 is misfiring and i have just put new plugs gapped at .035 and wires.
what should i look at next?
thanks for yor help
john
Old Jun 22, 2006 | 07:19 PM
MdFormula350's Avatar
if u are sure its number five, check under the cap at number five for anything out of the ordinary, also carefully look at the plug to make sure it isnt cracked from putting it in. to check for any odd arching happening start the engine when its dark and see if u can see anything weird going on. I guess also make sure the wire is fully on both terminals (at the cap and at the plug.)
Old Jun 22, 2006 | 08:34 PM
Car: 91 Z28 1le
Engine: 5.7 350 TPI
well i have checked from the distibutor and it does look alright but every time i pull it off i really get shocked. Does that have anything to do with the problem? There are no cracks on the plug. Could it be a bad injector? How would i tell if it is?
thanks
Old Jun 22, 2006 | 09:28 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
Plug wires, cracked cap, firing order....
Old Jun 22, 2006 | 09:42 PM
Car: 91 Z28 1le
Engine: 5.7 350 TPI
It has new wires as of last night, and there are no visible cracks anywhere on the cap. What do you mean by firing order?
Old Jun 22, 2006 | 10:17 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
Some times you can mix up a wire
Old Jun 23, 2006 | 03:47 AM
Car: 91 Z28 1le
Engine: 5.7 350 TPI
The wires are in the right order, i just double checked. For some odd reason whenever i go to take off spark plug wire number 5 from the distibutor cap it shocks the crap out of me. This wire is the only one that does it and its the one misfiring. What would be the cause of this?
Old Jun 23, 2006 | 10:39 AM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
Valve adjustment....
Old Jun 23, 2006 | 10:45 AM
HOZZ4's Avatar
Car: 1988 CHEVROLET IROC-Z
Engine: 5.7 TUNED PORT INJECTION
Transmission: 700R4 AUTOMATIC
IT SOUNDS LIKE YOU HAVE A BREAK IN THE WIRE. I WOULD JUST ATTACH AN OLD WIRE IN THAT SPOT TO TEST IF THE WIRE IS BROKEN.
Old Jun 23, 2006 | 02:25 PM
Car: 91 Z28 1le
Engine: 5.7 350 TPI
when i had the old wires in it did the same thing, so i bought the new wires and plugs trying to solve the problem and it did nothing. I just noticed last night when i checked for cracks(which there were none) on the distributor that #5 shocks me when i go to pull it off and none of the others do. What would be causing this?
Old Jun 23, 2006 | 02:42 PM
305TA85's Avatar
Car: 85 T/A & 98 T/A
Engine: 305 tpi/ 5.7 LS1
Transmission: 700 r4/ T-56
Axle/Gears: 3.23/ 3.42
How much grease is on your plug and wire? What does the plug look like? Condition it is in, not brand name. Were the plugs taylored by you or the factory? Did you pull the boot out of place? Do you have headers? How close is the wire to the exhaust manifold? Answer these questions and your problems should be solved on the ignition end.
Old Jun 23, 2006 | 10:18 PM
Car: 91 Z28 1le
Engine: 5.7 350 TPI
well the plugs and wires are brand new and look good. i also checked all of the wires to make sure all were secure....and today i just put new distributor cap on it an wire #5 still shocks me when i touch from dist. cap....do you think it could be a clogged injector?
it did the same thing with the old wire on it...i don't understand what else could make it do this because i just put new distributor cap on and it did the same thing.
thanks
Last edited by blackz281le; Jun 23, 2006 at 10:21 PM. Reason: Automerged Doublepost
Old Jun 24, 2006 | 12:12 AM
80Sierra's Avatar
Car: 80 GMC K35
Engine: TPI 355
Transmission: NV4500
Axle/Gears: 4.10
I think it is probally a cracked distributer cap. Electrons don't need a lot of room to squeeze through. It could be a crack so minor that you couldn't possibly see it, but being shocked constantly, even with new plug wires and plugs indicates a problem with the cap
You'd think you just like getting zapped with 50 000 volts or something, LOL
Old Jun 24, 2006 | 03:11 AM
Car: 91 Z28 1le
Engine: 5.7 350 TPI
I already bought a new one and installed it just 24 hours ago and it is doing the same thing still. What is causing this damn shock?
Old Jun 24, 2006 | 09:35 AM
HOZZ4's Avatar
IS THE DISTRIBUTOR THE OLDER BIGGER STYLE? IF NOT, MAYBE THE COIL WIRE TO THE CAP IS CRAP.
Old Jun 26, 2006 | 07:57 PM
Car: 91 Z28 1le
Engine: 5.7 350 TPI
ok so i have replaced the plugs, wires, and distributor cap. last night i did a compression chack on all of the cylinders and they are all good...and plug 5 seemed like it is getting fuel but still missing...now should i start looking internaly like valves or even cam. the guy that i bought it from told me he put a larger cam in it and it may be too big for the car...could this cause a misfire?
thanks to all who have helped
Old Jun 27, 2006 | 06:55 PM
Car: 91 Z28 1le
Engine: 5.7 350 TPI
anybody..............????????
Old Jul 1, 2006 | 02:44 AM
Car: 91 Z28 1le
Engine: 5.7 350 TPI
so could a larger cam cause a misfire or engine jolt that feels like misfire?
canged injector and looked at cam lobes, they looked fine.
Old Jul 1, 2006 | 02:52 AM
cohan305ci's Avatar
Car: 87 Z28
Engine: 305 ci TPI
i think that cudda caused it, cuz my friends trans am had a similiar problem, n the reason was cuz of the cam but i cant remember the details, ill hafta ask him next time i c him
db057
Jan 10, 2020 08:55 PM
NZKnight
Oct 15, 2015 02:47 PM
camarohelp
Sep 22, 2015 03:19 PM
Jk_Under
Sep 8, 2015 08:13 AM
Thaney9
Aug 29, 2015 03:16 PM
