Harmonic Damper/Balancer mark question
Old Jun 26, 2006 | 10:51 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
Quick question for you TPI people who have had their balancer off..
Let's Pretend the crankshaft keyway is considered 12:00.
Where in relation is the TDC marker on the outer ring?
I'd assume it should be 2:00 since thats where 0* is on the timing pointer on the timing chain cover.
I think I may have picked up the wrong balancer from the autoparts store because the TDC mark on the balancer is almost inline with the keyway.. I assume this balancer is for old SBC's and trucks that have the timing pointer at the 12:00 position.
Any help would be great...
Old Jun 26, 2006 | 11:17 PM
TPI Monte SS's Avatar
Car: 1988 Monte SS
Engine: ZZ4-cammed TPI 355
Transmission: World-Class T5
On our "late-model" Gen I SBCs, the keyway should be at 12 o'clock, with the 0* mark at approx. 2 o'clock. Indeed, sounds like they gave you the wrong balancer.
Old Jun 26, 2006 | 11:31 PM
Alright..Thanks man.
Old Jun 27, 2006 | 05:55 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The keyway is in-line with the #1/#2 crank throw, so at #1 TDC it should be at 45 degrees, not 12:00.
Old Jun 27, 2006 | 10:57 PM
Vader's Avatar
What he said:
Old Jun 27, 2006 | 11:20 PM
Originally Posted by Vader
What he said:
I understand now.
I have the right balancer.
Thanks for the pic
Old Jun 27, 2006 | 11:42 PM
1991L98G92's Avatar
Car: 91 Z28 24th Anniversary
Axle/Gears: Posi 3.23
That being a picture of an orange engine would have the correct mark for a 60's style mark. For a tuned port, the correct mark would be just about straight up since the timing mark indicator would be viewed from the top behind the water pump, wouldn't it?.
Old Jun 27, 2006 | 11:48 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Right, the difference between the balancers is still the relative location of the keyway and timing mark.
NiG
Sep 2, 2015 06:54 AM
gixxer92
Sep 1, 2015 04:32 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
