'86 TPI, sensors?
Old Jul 9, 2006 | 04:13 PM
tpi90rs's Avatar
Car: 87 Formula 350
Engine: 350tpi
Transmission: TH700R4
Axle/Gears: 3.23 limited
'86 TPI, sensors?
I don't know much about TPI's, is there a sensor for the exhaust?
if there is will it run without it? I have long tube headers without the threaded port, and I plan on running dual exhaust instead of Y-pipe into a cat. I can make a port for the sensor if it needs one, but will it work fine if it's only on 1 header?
Old Jul 9, 2006 | 05:20 PM
alabama_lowlife's Avatar
Car: nissan titan and nissan hardbody
Engine: 305 tpi
Transmission: manual
they sell weld in bungs for O2 sensors. mine has block huggers and both the headers feed to the same exhaust pipe. i'm not sure whether or not they HAVE to have sampling from both sides i would assume it does. but i'm sure somebody here knows the correct answer.
Old Jul 9, 2006 | 07:41 PM
Green89IROC305's Avatar
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
it only needs one. the computer wouldnt know what to do with another signal
Old Jul 9, 2006 | 09:07 PM
tpi90rs's Avatar
Car: 87 Formula 350
Engine: 350tpi
well that's obvious, but can that 1 sensor work fine on 1 header, or should I put in a X-pipe and mount the sensor right at the cross ?
Old Jul 9, 2006 | 09:49 PM
Engine: 383 HSR EBL
i think either would be fine but im not an 02 expert. i can ask around though.
Old Jul 10, 2006 | 09:01 AM
Engine: 383 HSR EBL
just asked my teacher. baisically just put it in the driverside exaust pipe where the stock location is.
Old Jul 10, 2006 | 04:36 PM
toddztoyz's Avatar
Car: 86 Monte Carlo SS
Engine: 5.0 liter High Output w/ TPI
Transmission: built 700R4 Auto
Axle/Gears: 10 bolt 3.73
This is where I put mine. I have flowtech longtubes and the sensor is in the collector of the drivers side header and it works fine. It is possible that you may need to switch to heated o2 sensors though if your computer does not see the o2 sensor. The farther away from the exhuast ports you get the cooler the exhaust is and the harder it is for the o2 sensor to work. I have not had any problem though. I am also running a true dual 3" exhaust on my Monte SS.
Old Jul 10, 2006 | 04:39 PM
tpi90rs's Avatar
Car: 87 Formula 350
Engine: 350tpi
awesome, now ask your teacher another question for me lol if you can.
ask him if a stock ECM can control different size fuel injectors accurately without programming.
That's the main question that's bothering me about this engine swap! Thanks man
Old Jul 10, 2006 | 09:41 PM
Engine: 383 HSR EBL
ill ask him tomorrow
Old Jul 11, 2006 | 06:58 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
tpi90rs, No, the ECM can't control different size injectors w/out programming. However, burn your own chips and you can use many different size injectors. I've gone from stock 19# injectors on the original 305 to 24# injectors on the 355 with SLP runners to 30# injectors with the HSR intake.
Caspar
Jun 19, 2016 11:19 PM
stalkier
Dec 6, 2015 11:25 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
