Cold start switch part#
Old Aug 1, 2006 | 03:59 PM
Rickdeluxe's Avatar
For some reason the TPI engine I got came without the cold-start-switch. Since I am getting ready to start the engine after putting it in a '69 Camaro, I need it! It sits right above the 'coolant temp sensor'.
The engine is a '89 Firebird 305 TPI. The wiring will be Painless...
What I need is a Delco part number so I can go to my GM dealer end order it.
Hope anyone can help me, I tried a search in these here forums but I couldn't find the 'search' button. The thing is a bit of a mystery... All part #s are in the Painless manual, except that one. If I Google it doesn't show up, even the GM parts online catalogs make it unfindable...
Please... Thanks!
Rick
Old Aug 1, 2006 | 04:02 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
If your up for it, Just put a plug there and upgrade to a 89 chip without vats
Uses enrichment threw the normal injectors and is a better system
Dont know the part # on that cold start switch though sorry
Old Aug 1, 2006 | 05:24 PM
Guest
Guest
Posts: n/a
Funny, he said he has an 89 305... that means there wasnt a cold start to begin with. Explains why its not there. Anyway the factory part if you actually needed one is a Bosch part and was used from 85-88. It also fits some VW's but I forget which.
What chip are you using? Thats a little more important. If its an 89 chip, you need the VATS setup in the car or you need to disable it in the chip.
Old Aug 1, 2006 | 05:56 PM
alabama_lowlife's Avatar
Car: nissan titan and nissan hardbody
Engine: 305 tpi
Transmission: manual
rick,
if you do need one, you can get one from TPI PARTS if you aren't certain about the year, check to see if you have the provisions for a cold start injector in your driver side runner.
Old Aug 2, 2006 | 03:30 AM
Rickdeluxe's Avatar
'89 is the year they stopped the ninth injector... The engine that I have before me is a 'yes-no' case probably. Some of the parts are there, some are not. There was a CSS, but it was taped to the outside of a heaterhose... And there is a ninth injector on the manifold! Also there is a hole for the CSS, right above the coolant temp sensor.
If you wanna check for yourself, come and see, the car and engine are in The Netherlands, that's Europe!
Anyway, the engine was dumped with us, told to be a '86 350 from a Z28 Camaro. When we checked the engine # the outcome was: '89 Firebird 305...
I am just the guy turning the wrenches, owner came up with the engine... After a lot of checking and studying I am nearly there, just need the funking CSS.
Found one at TPI parts, now I need the Delco #.
Old Aug 2, 2006 | 12:57 PM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
Hey buddy whats up.
I'm a parts counter rep at a local GM dealership.
The part# on that cold start switch is 14084318. Delco #212-312.
Hope this helps
Old Aug 3, 2006 | 05:49 AM
Rickdeluxe's Avatar
Thanks! That helps!
Much appreciated!
Rick
Old Aug 3, 2006 | 05:55 AM
Rickdeluxe's Avatar
Oh, that's strange...
Delco says it's the injector
Napa says it's the switch...
I need the switch.
Old Aug 3, 2006 | 07:48 AM
freestylzz's Avatar
Car: 1987 Iroc Z28
According to my GM catalogue and GM Info access page both those #'s are for the switch, not the injector.
Call your local GM dealer or auto parts supplier and use the 8 digit GM # (14084318).
Old Aug 3, 2006 | 04:04 PM
Rickdeluxe's Avatar
Thanks Freestylzz,
I'll look into that! Difficult is, the nearest GM dealer is far away... normally I order parts through a parts guy. Special orders are non refundable...
So I'll do the next best thing, I'll come to the US! Next month I'll be spending my holidays in California, see if I can find me a GM dealer!
Thanks for the #!
Old Aug 3, 2006 | 07:52 PM
freestylzz's Avatar
Car: 1987 Iroc Z28
No problem Rick.
And if you don't find it and trust in me to send it to you, I don't mind. I have a Paypal account with over 200+ positive feedback and I'm willing to help you out by sending it to you overseas if you'd like.
Give me a shout. Take it easy!
Old Dec 18, 2021 | 04:53 PM
BBennett.777777's Avatar
Re: Cold start switch part#
Hi freestylzz i will buy one of your #14084318 Cold Start Injector Switch # 19244930 new gm part number i am told send me an email please billbennettmotors@rogers.com
Old Dec 18, 2021 | 04:55 PM
Old Dec 23, 2021 | 04:51 PM
KR81's Avatar
Thread is 15 years years old man and he hasn't been active since 2013, you'll be better off searching the part number yourself. There's one listed on ebay but it's from a corvette parts guy so it isn't cheap. Goodluck.
Actually scratch that, it's out of stock. You'll be better off deleting the cold start system as described above.
Old Mar 7, 2022 | 10:14 PM
pmatrace's Avatar
Found the Switch, Cold Start F/inj (AC Delco 212-312) searched both the AC number and 19244930. Summit Racing has 2 left for a decent price. Others wanted from $ 137.00 to $ 250.00. My car is a 1986 IROC with the 305 TPI engine(LB9). Going thru the motor now. Replacing all the original sensors.
In checking the fit it lists all the 305 motors used in trucks etc. It connects to my Painless wiring system. Summit part # ADO-213-192. My connector looks like this
Old Mar 8, 2022 | 04:01 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Easiest fix delete by using a 89 tune. You have pictured a iat
gmglenn99
May 13, 2016 12:59 AM
gluck86
Mar 8, 2011 01:03 PM
My1986IROC-Z
Jul 5, 2006 09:26 PM
mopain
Sep 3, 2005 06:40 AM
JOHNCOO5
Dec 12, 2004 07:30 PM
