Headers out of the way???
Old Aug 13, 2006 | 05:48 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Transmission: stage2 700r4
Axle/Gears: 2.73 for now
Really stuck on a problem, and its almost causing me to light a match under my iroc. I have a 87 305, and im trying to get the heads off. I just pulled the headers off, but it does not give me enough room to get to the head bolts along the bottom.
I tried using a pry bar, but I can only get the headers to move back about an inch. How do I get the headers away from the block enough so that I can get to the bottom head bolts. Its hot outside, and im getting frustrated. Im sure there is an easier way to do this? Thanks guys.
Old Aug 13, 2006 | 06:50 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
come on guys...dont mean to bug...but im sure someone knows how...especially the last 2 header bolts on the passenger side closest to the firewall...practically impossible.
Old Aug 13, 2006 | 09:32 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
have you tried unbolting the headers from the collectors?
Old Aug 13, 2006 | 11:14 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Very slowly and painfully :-)
Cut/bend/torch a wrench as neccesary to fit the application and give it a special spot in your toolbox.
Its just how it is.
I have a cut down wrench that I use and about 2-3 other 7/16 ones with varying degrees of backsweep and angle on them.
I use all of them at some point on the back bolts.
later
Jeremy
Old Aug 14, 2006 | 08:42 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Yes its a long and painfull process. Sometimes you can only turn those bolts 1/4 at a time.....theres just not alot of room. Like 3.8Transam said. I even have a special wrench I grinded down to fit on my header bolts in the tight spots. Even the spark plugs arent fun to get to after I put my headers on. I have the ceramic coated headers so at leats it cools down quick. Best way to get those is from the bottom side. I'm gald we have a hoist, my car has been up and down more time then I can count. Because once you get headers....we all know you have to tighten them up every now and then. Good luck and let us know if you got them off.
Old Aug 14, 2006 | 01:06 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Yup. found this out the hard way. Had to remove them from the collectors, and it made it easier. I had use a different ratchet, extension, and length socket for just about every bolt. Thanks guys., and Ill be holding off on lightinh that match...
BTW..does anyone know where to post introductions? I just bought my car, and would like to properly introduce myself, and my car on this forum.
Old Aug 14, 2006 | 03:49 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
You know what also helps is buying a good set of header bolts! My brother in law had a set of chrome ones that had 12 points, so I could use a 12 point wrench. It made things alot easier to work on.
Old Aug 14, 2006 | 06:40 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
i got the stage 8 header bolts and haven't had to retighten header bolts in 6 years.
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
