TB bypass and breather ???
Old Sep 7, 2006 | 03:38 PM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Hi, I just bypassed the cooling lies that went to my TB. Now here are my questions.
1st. What should I do with the two openings on my TB now. Should I cap them, or plumb them for more cold air??? What did you do??
2nd. In the picture below this hose goes from the valve cover to the TB. Now, pulled it off the TB and there was oil there??? I don't think thats good. Should I just yank that and put in a breather there??? What did you do, and what do you suggest???
Old Sep 7, 2006 | 03:46 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
First, You can just leave the coolant barb fittings open - wont hurt anything.
Second, Leave the tube running from the valve cover to the throttle body there. It provides fresh air to the crankcase when the pcv system is functioning correctly. It is normal to have a little oil inside the tube.
Old Sep 7, 2006 | 03:52 PM
Do you think a breather would help it more???
I failed emissions, and I know one of the tricks is to take out the PCV valve to let the engine breathe more. I thoght I could possibly cheat the system with a gutted breather or sumtin.
Hmmm.
Old Sep 8, 2006 | 06:58 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Do you have the numbers from the test?
I would guess if you had a malfunctioning pcv system it would give you high HC but if your state does not require a visual inspection then a breather would be ok. Only problem is that when the pcv valve is not open the breather will let oil vapor out and it just kindof stinks and gets on stuff.
Old Sep 12, 2006 | 06:25 AM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
putting a breather in place of the pcv system will help the emission test because it wont go back through the engine and out the tail pipe. but it will infact put out more emission through the breather because it is not being put through the combustion process. although the pcv system is alot better than the breather system for the engine itself because it puts a vacum on the crankcase to help ventalate it rather than just pour it out. so if you dont have a visual inspection just put a breather in there and then after you pass the test, hook the pcv system back up.
Old Sep 15, 2006 | 05:41 AM
1991Camaroz28's Avatar
Car: 91 Z28
Transmission: TH700-R4
i have a problem with that same line pictured at the top of the thread. when it was attached to the TB the other end would blow out of the valve cover. i replaced the grommet with a new one that held it tighter and it still pops out. so i got a breather to put on it and there is smoke coming out of it. why is it doing that and how do i fix it?
Old Sep 15, 2006 | 06:58 AM
QuickStyle's Avatar
Car: 91 Z28
have you tried replacing the pcv valce itself, might have been plugged up and instead of sucking it back in through the intake, it was forced out by the ventalation.
Old Sep 15, 2006 | 07:35 AM
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
Axle/Gears: 3:23 Posi
Ive seen that happen on a few other cars. You should check that the PCV valve is working correctly and its getting good vacuumn to it. Ive seen where cars do alot of stop and go driving and the ports get clogged with sludge and prevent the pcv valve from working correctly. Cleaning those ports out and driving the car on the highway will usually get things working again. Its important to get the oil nice and hot, then change it to help drain all the garbage out.
Old Sep 15, 2006 | 08:44 AM
Car: 91 Z28
well the pcv rattles so the valve is good. it's probably what you said about clogged with sluge. time for an oil change anyway.
Old Mar 27, 2007 | 12:36 AM
drb930's Avatar
Car: 1987 Chevy El Camino
Engine: 357 CID w/Lingerfelter Super Ram
Transmission: 700-R4
Axle/Gears: GN 8.5 342's
Re: TB buypass and breather ???
Anyone know the truth about running a Stock Cast Dist Geat against the LPE 74219 Cam?
Comp Cams that makes the cam for LPE says that you cant do it?
Old Mar 28, 2007 | 02:29 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
why the he** would you ask that question in this thread?
Old Mar 28, 2007 | 03:07 PM
drb930's Avatar
because Quickstyle above has the same setup as i do!
Old Mar 28, 2007 | 03:33 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Just so you know, He may have unsubscribed to this thread so he would never recieve your reply in this post. Its usually better to ask setup specific questions in a PM.
Old Apr 15, 2007 | 04:22 AM
QuickStyle's Avatar
Car: 91 Z28
no im still here, i just ignored his question, because it seemed irrelivant to this tread, maybe he would have directed his question toward me more, it would have made a little more sense, but anyway, i have no answer to your question because i have the lpe cam and an msd billet distributor, and i used the gear it came with, and i dont know what kind of gear that is, sorry
$750 L98
Feb 1, 2025 02:25 PM
Pac J
May 17, 2020 10:44 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
sleprock
Sep 24, 2015 04:33 PM
Formula8r89
Sep 22, 2015 04:24 PM
